6584 Discussions
mvnc v2 read_elem hang with "dispatcherEventReceive() Read failed -1"
dispatcherEventReceive:200 dispatcherEventReceive() Read failed -1
I have been using the model available in the link.https://drive.google.com/open?id=0BzKzrI_SkD1_TkFPTEQ1Z091SUE
@fangyifei Are you able to get results when you receive this error? We are aware of an issue where this error message shows up, but the NCSDK and NCS functionality is unaffected.
If you can provide more information involving your setup (dedicated machine? vm? os?) it would be helpful. Thanks.
Hi, I am trying to perform inference using a Tiny Yolo v2 and I am experiencing the same dispatcherEventReceive:200 error:
I: [ 0] ncGraphQueueInference:3048 trigger start
I: [ 0] ncGraphQueueInference:3145 trigger end
E: [ 0] dispatcherEventReceive:200 dispatcherEventReceive() Read failed -4
Were you able to find a solution?
I am running Movidius in an Intel NUC D54250WYKH with Ubuntu 16.04 installed.
