New MVNCAPI is not working on RPi 3
After upgrading from V1 to V2, the new sample code is not working and I am getting this error:
pi@raspberrypi:~/face-recognition-model $ python main.py Starting Age/Gender detector E: [ 0] dispatcherEventReceive:200 dispatcherEventReceive() Read failed -1 ^CSegmentation fault pi@raspberrypi:~/face-recognition-model $
The script had frozen, and I had to press CTRL+C to close this script.
Do I have to upgrade the firmware of the NCS? If so, how can I do it?
Otherwise, is there any way to debug it?
Cheers.
@scarlyon You don't need to upgrade the firmware of the NCS device. I don't recognize the sample code you are referring to above: face-recognition-model, but the Caffe Age and Gender models should be working with NCSDK v2. Try running some of the included NCSDK 2 examples and see if they work for you.
Hi, I am trying to perform inference using a Tiny Yolo v2 and I am experiencing the same dispatcherEventReceive:200 error:
I: [ 0] ncGraphQueueInference:3048 trigger start
I: [ 0] ncGraphQueueInference:3145 trigger end
E: [ 0] dispatcherEventReceive:200 dispatcherEventReceive() Read failed -4
Were you able to find a solution?
I am running Movidius in an Intel NUC D54250WYKH with Ubuntu 16.04 installed.
