6584 Discussions
Inconsistent results between OpenVINO for Windows and Linux
fabda01
I installed OpenVINO 2020.3 for both Windows and Linux, then compiled the hello_classification sample to check the instalation.
The parameters for hello_classification are:
model: resnet-50-tf
image: cat.bmp
device: CPU
For convenience, I provide the files https://drive.google.com/drive/folders/1UvLBQuaiRK5A16m84GGxE5_1Jz8kTo5c?usp=sharing
The output for Windows is
Top 10 results:
classid probability
754 0.2142971
540 0.1585525
859 0.1001580
905 0.0999501
906 0.0711121
808 0.0357422
78 0.0212184
704 0.0110239
717 0.0107170
784 0.0103809
But the output for Linux is
Top 10 results:
classid probability
283 0.3173478
286 0.3094152
282 0.2304513
621 0.0268417
540 0.0189033
812 0.0108505
754 0.0065848
285 0.0064078
288 0.0053420
905 0.0048294
Which one is the correct output?
IntelSupport
Community Manager
Hi Davi,
Thank you for reaching out to us. We are currently investigating this issue and will come back to you soon.
Adli
Adli
Hi Davi,
Currently, we're still investigating this issue. Thank you for your patience.
Adli
Adli
Hi Davi,
Thank you for your patience. The root cause of this issue is due to the sample enables support for Unicode paths. Currently, we are looking for the right fix. For the time being, we suggest our users utilize another sample, for example, the 'classification_sample_async' sample. We also recommend our users to build a sample without the ENABLE_UNICODE_PATH_SUPPORT option. We apologize for the inconvenience.
Adli
Adli
Hi Davi,
A quick update to you. A fix for this issue has been implemented into the open-source OpenVINO master branch. The fix also should be available as a part of the Intel Distribution OpenVINO release soon. Feel free to test the sample demo. Thank you.
Adli
Adli
Hi Davi,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Adli
