Infer vs StartAsync
serg
Hello...
Is any performance (or..) difference between
inferRequest.Infer();
vs
inferRequest.StartAsync();
if (InferenceEngine::OK != inferRequest.Wait(InferenceEngine::IInferRequest::WaitMode::RESULT_READY))
In video cource, the Man says - it is faster, but without explanation.
Munesh_Intel
Hi Sergey,
InferenceEngine::InferRequest Class Reference page is available at
https://docs.openvinotoolkit.org/2021.1/classInferenceEngine_1_1InferRequest.html
InferenceEngine::InferRequest::Infer  infers specified input(s) in synchronous mode.
https://docs.openvinotoolkit.org/2021.1/classInferenceEngine_1_1InferRequest.html#a3391ce30894abde730523e9ca9371ce8
InferenceEngine::InferRequest::StartAsync starts inference of specified input(s) in asynchronous mode.
https://docs.openvinotoolkit.org/2021.1/classInferenceEngine_1_1InferRequest.html#a405293e8423d82a5b45f642a3bef0d24
For more information, please refer to point 7 in the following section:
https://docs.openvinotoolkit.org/2021.1/openvino_docs_IE_DG_Integrate_with_customer_application_new_API.html#integration_steps
To estimate deep learning inference performance on supported devices, I would suggest you use Benchmark C++ Tool. Performance can be measured for two inference modes: synchronous (latency-oriented) and asynchronous (throughput-oriented). You can use -api command-line parameter to define the inference mode.
https://docs.openvinotoolkit.org/2021.1/openvino_inference_engine_samples_benchmark_app_README.html
Munesh
Munesh_Intel
Hi Sergey.
This thread will no longer be monitored since we have provided information and suggestion. If you need any additional information from Intel, please submit a new question.
Munesh
