6580 Discussions
Inference Engin EXCEPTION C++ visual studio
ghadiri__masoud
SS
hello everybody
i installed openvino library with this tutorial this
and i link visual studio to inference engine library like this image
and lib folder and Files are in this image
my problem is in c++ code  sample
when visual studio runinng program
i get this error exception that .
exceptionErrorImage
this is the error text
Unhandled exception at 0x00007FF9D7BF4048 in Openvino_cv64_number2.exe: Microsoft C++ exception: InferenceEngine::details::InferenceEngineException at memory location 0x000000BF8EAFE5D0.
for the first line .
Core ie;
my laptop is lenovoE530
intel i5-3210M
i test my code with other system
with this details
intel corei7 8700k
but same error for running .
please help me .
JesusE_Intel
Hi masoud,
You mentioned a guide but I do not see the link. Could you share the link to the document you are following?
Also, please note that the OpenVINO toolkit has only been tested on 6th to 10th generation Intel® Core™ and Intel® Xeon® processors.
Jesus
Li__Jisheng
hello, below is my problem.
int main()
    string xml = "C:/Intel/openvino_2020.2.117/deployment_tools/tools/model_downloader/intel/yolo - v2 - ava - 0001/FP32/yolo-v2-ava-0001.xml";
    string bin = "C:/Intel/openvino_2020.2.117/deployment_tools/tools/model_downloader/intel/yolo - v2 - ava - 0001/FP32/yolo-v2-ava-0001.bin";
    InferenceEngine::Core core;
when I  run my code and it goes to  InferenceEngine::Core core; it appears the error below.
0x000007FEFD37A06D location(at openvinopersondetect2020version.exe )not handle exception: Microsoft C++ exception: InferenceEngine::details::InferenceEngineException,locate at RAM 0x00000000002CDBE0 . I use the w_openvino_toolkit_p_2020.2.117 version. Could you please give me any suggestion? by the way, I use visual studio 2017, win7.  i7-6500 cpu Intel(R)HD Graphics 520. Hopefully someone can give me a hand!! thanks a lot
Besma_Guesmi
Hi
Did you solve the problem? if so, could tell me how you solved it please ? because I faced the same error.
galligio
did u try to catch the exception to see what the problem is? Something like
try
catch(std::exception &e)
cout << "failed to initialize core: " << e.what() << std::endl;
Or you can log the error into some txt file if you are using some tool (e.g. Easylogger)
