Inference Engine output OpenVINO toolkit
SDabh1
Hello All,
I am using OpenVINO toolkit and I was wondering if there is any way possible to get .cpp and .cl files from inference engine. I am new to this tool and trying to understand the FPGA flow.
I am following this link: "https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_linux_fpga.html#inpage-nav-5-2-1"
I have couple of questions:
1. Do I need to connect board to my workstation(I don't have arria10gx board)? Is there is any way, I do not connect board to my workstation and then just try to get .aocx, .cpp and .cl files?
2.I am curious about how this .aocx files are getting generated?
3.Do I need to use pre-build .aocx file only or I can generate new .aocx with my new NN model?
4. Can anyone point me to a link, end to end working example for fpga platform?
I would really appreciate if anyone can throw a light on this.
Thank you and regards
Shubha_R_Intel
Dear Dabhade, Sunil
May I ask why you want to get the aocx files if you don't have a board?  You can generate aocx files with the developer package (available under certain Intel agreements such as SLA).  If you don't have the developer package, then you must use the pre-built ones.
Inference engine source code is available from OpenVINO open source project, https://github.com/opencv/dldt.  The FPGA Plugin source code is not open-sourced however.
Hope it helps,
Thanks !
Shubha
SDabh1
Sure Shubha,
Thank you for the reply!
I don't have a gx board but I have sx board. So I was thinking if I know how to generate the .aocx file I can try same thing for sx board. Anyways, for now, I got the process how to generate .aocx file but is it possible to generate for sx board? If yes, can you provide me some example?
Thanks in advance.
Shubha_R_Intel
Dear Dabhade, Sunil,
Unfortunately this question is outside of the scope of this forum. Please talk to your intel representative.
Shubha
