6593 Discussions
Inference problem of Openvino with ssd_mobilenet_v1_coco
Liang__JianWei
hellow, i have some question about the inference result of openvino IR
I download the ssd_mobilenet_v1_coco_2018_01_28 from  https://software.intel.com/en-us/articles/OpenVINO-Using-TensorFlow
than I convert the download model to openvino IR format using the following command
python mo_tf.py --input_model <frozen_inference_graph.pb model path> --tensorflow_use_custom_operations_config <openvino path>\deployment_tools\model_optimizer\extensions\front\tf\ssd_support.json --tensorflow_object_detection_api_pipeline_config <pipeline.config path> --input_shape [1,300,300,3]
I convert the model successfully
however when I inference an image using the IR, the result is different from the tensorflow result using frozen_inference_graph.pb
for example, when I inference an image using frozen_inference_graph.pb , I find out all the detected objects with score larger than 30%:tensorflow_result.png
however,when I inference an image using openvino IR and get detected objects with scores larger than 30%, it come out many unexpected boxes:
although the 2 objects with largest scores (70%, 62%) is the same with tensorflow result(see the following picture), there are many unexpected boxes with scores about 51%~52%
what I want to know is that is my result is correct?
if I set scores threshold to filter detected objects, I will get many unexpected results, how can I solve it?
is anybody can help? thank you vary much!
Liang__JianWei
is there anyone can give me some help?
Shubha_R_Intel
Dear Liang, JianWei,
Most likely you did not pass in proper pre-processing switches into Model Optimizer.  Please review this IDZ post. Actually we provide mean and scale values for the most popular models (including mobilenet) on this page:
http://docs.openvinotoolkit.org/latest/_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html
Hope it helps !
Shubha
