6575 Discussions
InferenceEngineException on raspberrypi 'Product of output shape dimensions does not match product of argument shape dimensions'
pchilders
When following the instructions on https://docs.openvinotoolkit.org/latest/_docs_install_guides_installing_openvino_raspbian.html I get the following errors.
I was able to test the NCS on Mac OS, so it seems to be related to the raspberry pi build.
pi@raspberrypi:~/build $ python3 openvino_fd_myrad.py
terminate called after throwing an instance of 'InferenceEngine::details::InferenceEngineException'
  what():  conv4_3_0_norm_mbox_priorbox/naked_not_unsqueezed has zero dimension that is not allowable
Aborted
  what():  Check 'input_shape_product.get_length() == shape_size(m_output_shape)' failed at /teamcity/work/scoring_engine_build/releases_2020_2/ngraph/src/ngraph/op/reshape.cpp:100:
While validating node 'v0::Reshape Reshape_980(PriorBox_754[0]:f32{2,3231918080}) -> (dynamic?)':
Product of output shape dimensions does not match product of argument shape dimensions (output shape: Shape{1, 2, 3231918080}, argument shape: {2,3231918080}).
Any idea what is the error?
RandallMan_B_Intel
This issue is discussed in this thread.
Randall
