Input models for model optimizer
m_v__vyshak
Hi
I am using model optimizer to produce a valid Intermediate Representation (.xml and .bin). I want to generate .xml and .bin for the sample “interactive face detection” available within the open vino toolkit
Eventhough there are pre trained models available (face-detection-adas-0001), how can i generate the .xml and .bin files using the command
python3 mo.py –input_model <path_to_model>.caffemodel –input_proto ~/opt/intel/computer_vision_sdk_2018.3.343/deployment_tools/intel_models/face-detection-adas-0001/face-detection-adas-0001.prototxt
I could find the .prototxt file. The question is where can i get the input model files (.caffemodel or .tensorflow). Since i am new to this, it would be helpful if i could get the path or way to get these input model files
Additionally i tried the command
python3 mo.py –input_model /opt/intel/computer_vision_sdk_2018.3.343/deployment_tools/intel_models/face-detection-adas-0001.caffemodel –input_proto /opt/intel/computer_vision_sdk_2018.3.343/deployment_tools/intel_models/face-detection-adas-0001/face-detection-adas-0001.prototxt
This command threw me the following error :
[ ERROR ] The "../intel_models/face-detection-adas-0001.caffemodel" is not existing file
Sreedhar_V_Intel
Hi Vyshak,
If you install latest OpenVino tool kit, all pre trained models will be copied to /home/youruserid/openvino_models
mahinlma
This directory /home/openvino_models has only Squeezenet caffe model.
Sandhu__Ranjit
Morning,
I am also facing same problem as Natarajan,So any idea how to get those models ?
~ranjit
Sandhu__Ranjit
I think we need to run script under ..\deployment_tools\model_downloader\downloader.py yo get the models ...
~ranjit
Mc__Andrew
This doesn't seem to be explained anywhere but you can download them from here: https://download.01.org/opencv/2019/open_model_zoo/R1/models_bin/
Shubha_R_Intel
Thank you Sandhu, Ranjit and Mc, Andrew, for answering the question. Actually the download site for the models is mentioned in the actual sample documentation, for example Action Recognition Demo . If you use downloader.py pass in the --all switch which will download all the models.
Shubha
