Model Optimizer did not work for CenterNet
Zhiming
I was running the Keras version of CenterNet available here https://github.com/see--/keras-centernet. Now I am trying to run the model on the Intel Compute Stick 2. But when I tried to transform the frozen tensorflow model to the IR, I got errors 'Graph contains cycle'.
Here are some steps to reproduce the error.
1. Git clone the project
2. Replace the _process_sample function in keras-centernet/keras_centernet/models/decode.py with the following to avoid the data type mismatches in the model optimizer.
def _process_sample(args):
    _hm, _reg, _wh = args
    _scores, _inds = tf.math.top_k(_hm, k=k, sorted=True)
    _classes = K.cast(_inds % cat, 'float64')
    #width = K.cast(width, 'float32')
    _inds = K.cast(_inds / cat, 'float64')
    _xs = K.cast(_inds % width, 'float64')
    _ys = K.cast(K.cast(_inds / width, 'float64'), 'float64')
    _inds = K.cast(_inds, 'int32')
    _xs = K.cast(_xs, 'float32')
    _ys = K.cast(_ys, 'float32')
    _classes = K.cast(_classes, 'float32')
    _wh = K.gather(_wh, _inds)
    _reg = K.gather(_reg, _inds)
    _xs = _xs + _reg[..., 0]
    _ys = _ys + _reg[..., 1]
    _x1 = _xs - _wh[..., 0] / 2
    _y1 = _ys - _wh[..., 1] / 2
    _x2 = _xs + _wh[..., 0] / 2
    _y2 = _ys + _wh[..., 1] / 2
    # rescale to image coordinates
    _x1 = output_stride * _x1
    _y1 = output_stride * _y1
    _x2 = output_stride * _x2
    _y2 = output_stride * _y2
    _detection = K.stack([_x1, _y1, _x2, _y2, _scores, _classes], -1)
    return _detection
  detections = K.map_fn(_process_sample, [hm_flat, reg_flat, wh_flat], dtype=K.floatx())
  return detections
3. In keras_centernet/bin/ctdet_image.py, generate the frozen TensorFlow model using the following code:
  num_output = 1
  predictions = [None] * num_output
  predrediction_node_names = [None] * num_output
  for i in range(num_output):
    predrediction_node_names = 'output_node' + str(i)
    predictions = tf.identity(model.outputs,
    name=predrediction_node_names)
  sess = K.get_session()
  constant_graph = graph_util.convert_variables_to_constants(sess,
  sess.graph.as_graph_def(), predrediction_node_names)
  infer_graph = graph_util.remove_training_nodes(constant_graph)
  graph_io.write_graph(infer_graph, '.', 'tf_model_new2', as_text=False)
4. Run the following command to run the keras-CenterNet and obtain the frozen tensorflow model.
PYTHONPATH=. python keras_centernet/bin/ctdet_image.py --fn assets/demo2.jpg --inres 512,512  (Note you can run this on a docker)
5. Use the following command in the model optimizer to generate the IR
sudo python3 mo_tf.py --input_model ~/keras-centernet/model/tf_model_new2.pb --log_level=DEBUG --input_shape=[1,512,512,3] --data_type FP16
Kindly let me know if you need more information. Thanks!
Shubha_R_Intel
Dear Hu, Zhiming,
CenterNet is not one of the supported (validated) Model Optimizer models. You do have some options for this error, however, please see the MO FAQ # 97. Please check out Offloading Sub-Graph Inference to TensorFlow .
Shubha
Zhiming
Shubha R. (Intel) wrote:
Dear Hu, Zhiming,
Shubha
Thanks very much for the reply. I have looked at the two options: tensorflow_subgraph_patterns and tensorflow_operation_patterns. As there are no error messages suggesting which operators are not supported, maybe I should use the first command line option. Is that correct?
Another question is that I have no idea about what sub-graphs should be offloaded to the tensorflow as there are too many cycles in the architecture for the model. I have attached the graph for the model. Could you please have a look at it and give some suggestions? Thanks again for your time and efforts!
Shubha_R_Intel
Dear Zhiming,
I haven't had a chance to investigate this yet, but please do a --log_level DEBUG in your Model Optimizer command. Does the offending cyclic node happen at the end of the model ? Somewhere in the middle ? If it's at the beginning or end, you can chop it off using the
 Model Cutting Technique . Basically by model cutting you are defining different entry and exit points to your model, and it may be OK for inference - your model may still work as long as you're not chopping off crucial parts.
Shubha
