6584 Discussions
Installation failed . Error on line 310
So I just received the NCS in the mail today. Attempting to install the SDK, but I'm running into some issues. I'm installing on my work laptop, running Ubuntu 16.04.4 and get the following results.
$sudo make install
Uninstalling opencv pip installation
sudo: pip3: command not found
Looking for opencv source installation
Err:30 https://download.docker.com/linux/ununtu xenial/stable amd64 Packages
404 Not Found
Reading package lists…
W: The repository 'https://download.docker.com/linux/ununtu xenial Release' does not have a Release file.
E: Failed to fetch https://download.docker.com/linux/ununtu/dists/xenial/stable/binary-amd64/Packages 404 Not Found
E: Some index files failed to download. They have been ignored, or old ones used instead.
Installing python dependencies…
./install-ncsdk.sh: line 289: pip3: command not found
The directory '/home/mascenzi/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/mascenzi/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Requirement already satisfied: Enum34>=1.1.6 in /usr/local/lib/python2.7/dist-packages (1.1.6)
Checking whether tensorflow is installed…
looking for tensorflow CPU version…
./install-ncsdk.sh: line 260: pip3: command not found
looking for tensorflow GPU version…
Couldn't find a supported tensorflow version, installing tensorflow v1.4.0
./install-ncsdk.sh: line 310: pip3: command not found
Installation failed. Error on line 310
Any suggestions as to what is going on and how to correct this?
Hi All, I have exactly the sane error with sdk version 2, in my case tensor flow version 1.6 is missed. Could somebody please assist?
Thanks in advance.
fpartika,
I ended up getting everything working, the problem was due to a previous installation of python/opencv. I ended up uninstalling opencv and re-installing it. Still came across some issues with linking libraries, but it was easier the second time around.
Michael
Is this what you're looking for?
sudo apt-get install python3-pip
Hello, I am having the same issue, here. Can you explain how did you uninstall opencv, please?
