6575 Discussions
Installation of NCSDK failed with Command 'sudo apt-get update' return code=100
I tried to make install in my Ubuntu 16.04.
When I tried make install inside ncsdk folder, I have errors as
E: Failed to fetch http://sg.archive.ubuntu.com/ubuntu/dists/xenial/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80] E: Failed to fetch http://archive.ubuntu.com/ubuntu/dists/trusty/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.162 80] E: Failed to fetch http://sg.archive.ubuntu.com/ubuntu/dists/xenial-updates/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80] E: Failed to fetch http://sg.archive.ubuntu.com/ubuntu/dists/xenial-backports/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80] E: Failed to fetch http://sg.archive.ubuntu.com/ubuntu/dists/xenial-security/main/binary-arm64/Packages 404 Not Found [IP: 91.189.88.152 80] E: Some index files failed to download. They have been ignored, or old ones used instead. Installation failed: Command 'sudo apt-get update' return code=100. Error on line 317 in ./install-utilities.sh. Will exit Makefile:47: recipe for target 'install' failed make: *** [install] Error 131
I changed in Softwares & Updates to Main Server and Singapore server. Both have not found [IP: 91.189.88.152 80] errors and failed.
How can I solve to install?
You will need to remove the foreign architecture "arm64" as the binary-arm64 url does not exist in the unbuntu archoives for xenial-backports.
You can refer to the link https://askubuntu.com/questions/917081/how-to-get-rid-of-arm64-in-apt to get rid of the arm64 i apt.
