Installing NC SDK - make examples error
I am following the instructions to setup the SDK from https://developer.movidius.com/start
When I run 'make examples' on the terminal window, I get the error message:
sed: 1: "ncsdk.conf": extra characters at the end of n command
make: *** [prereqs] Error 1
What does this mean?
@HSandison is it possible that you git cloned on a different machine than the one you are installing on? i.e. maybe cloned it on Windows and copied it to Ubuntu for installation? If not, can you please download a fresh copy of https://raw.githubusercontent.com/movidius/ncsdk/master/ncsdk.conf into your installation directory and try make install again?
Hi Ashwin,
Yes, that may be the problem. Thank you, I will try this.
This is now installing properly - many thanks.
