Intel Open VINO R4 corei7 8750H iGPU support?
taka
Can not OpenVINO run on Corei i7 8750H iGPU
The following message will be displayed
"[ERROR] failed to create engine: Device lookup failed -  unsupported device id:0x3E9B"
clDNN source(gpu_devices.inc) does not mention the device id
Will it be improved in the next version?
Reference URL
https://github.com/intel/clDNN/blob/master/src/caps/public/gpu_devices.inc
https://ark.intel.com/products/134906/Intel-Core-i7-8750H-Processor-9M-Cache-up-to-4-10-GHz-
nikos1
Valued Contributor I
Hello Takamitsu-san,
Looks like a typo in the clDNN code. Unofficial wiki https://en.wikipedia.org/wiki/List_of_Intel_graphics_processing_units shows your CPU has an 0x3E9B GPU and this is indeed what is reporting. 0x3E98 looks like a an 8 vs. B typo .
I can see the issue https://github.com/intel/clDNN/issues/47 was created
In the meantime, you may want to build clDNN from source and replace 0x3E98 by 0x3E9B
Cheers,
Nikos
taka
Hello Nikos,
0x3E98 exists. Is not not a mistake but a forgotten addition?
https://ark.intel.com/products/134896/Intel-Core-i5-9600K-Processor-9M-Cache-up-to-4-60-GHz-
Replacing openvino 's cldnn64.dll with cldnn' s build will fail with initialization
nikos1
Yes indeed, needs to be added! I was not aware of this CPU.
What compiler are you using? I would also try to build from source and link to my products. Maybe I will hit the same issue. Trying now..
taka
cldnn was built with visual studio2015.(Windows10)
openvino sample is also built with vs2015.
nikos1
Thanks! Also built with VS2015 64-bit Windows 10.  Just passed the default enabled unit tests - will try a repro
[==========] 659 tests from 98 test cases ran. (177287 ms total)
[  PASSED  ] 659 tests.
  YOU HAVE 17246 DISABLED TESTS
nikos1
Yes, getting issues here too. Maybe master is not stable. I am going to try earlier version
git checkout prod-2646
Checking out files: 100% (7903/7903), done.
Note: checking out 'prod-2646'.
You are in 'detached HEAD' state. You can look around, make experimental
changes and commit them, and you can discard any commits you make in this
state without impacting any branches by performing another checkout.
If you want to create a new branch to retain commits you create, you may
do so (now or later) by using -b with the checkout command again. Example:
  git checkout -b <new-branch-name>
HEAD is now at 5ef52733 offline data for mxnet
nikos1
Getting issues with prod-2646 too
nikos1
Anyone knows what version of clDNN was used in OpenVino 2018 R4 ?
Release notes mention Updated clDNN version to 9.1
How can we git checkout clDNN version 9.1 - what is the commit # ? Cannot find the product tag.
Nikos
nikos1
Better modify and build clDNN from  https://github.com/opencv/dldt/tree/2018_R4
https://github.com/opencv/dldt/tree/2018_R4/inference-engine/thirdparty/clDNN
R4 seems to be using clDNN Drop 9.1
taka
Thank you!
I was able to build clDNN Drop 9.1. Replacing cldnn64.dll, it worked properly with Corei i7 8750H.
Loza__dayannex
taka
Could you to build with i7-8750H ?, I' ve tried to build with visual studio 2017 and Sources Code 2019 R1  on Windows 10. I generated the solution inference-engine and dldt but when compiling an null exception is generated
