6586 Discussions
Internal Error when using Model Optimizer with Tensorflow
Patel__D
I am attempting to convert a tensorflow graph to a valid intermediate representation for use with the inference engine. I get the following internal error
[ ERROR ]  -------------------------------------------------
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  [Errno 13] Permission denied: 'C:\\Program Files (x86)\\IntelSWTools\\openvino\\deployment_tools\\model_optimizer\\.\\inference_graph.bin'
[ ERROR ]  Traceback (most recent call last):
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 298, in main
    return driver(argv)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\main.py", line 247, in driver
    is_binary=not argv.input_model_is_text)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 237, in tf2nx
    meta_info=meta_info)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\pipeline\common.py", line 132, in prepare_emit_ir
    serialize_constants(graph, bin_file)
  File "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\model_optimizer\mo\back\ie_ir_ver_2\emitter.py", line 41, in serialize_constants
    with open(bin_file_name, 'wb') as bin_file:
PermissionError: [Errno 13] Permission denied: 'C:\\Program Files (x86)\\IntelSWTools\\openvino\\deployment_tools\\model_optimizer\\.\\inference_graph.bin'
[ ERROR ]  ---------------- END OF BUG REPORT --------------
Luis_at_Intel
Hi Patel, D,
As the error "Permission denied: 'C:\\Program Files (x86)\\IntelSWTools\\openvino\\deployment_tools\\model_optimizer\\.\\inference_graph.bin'" suggests, it looks like there is an issue with writing permissions on the directory you are converting the model.
Since you are using Windows, I could suggest two things:
  • Open a Command Prompt and run as Administrator so it can write to such directory
  • Change to a directory that doesn't need Admin rights to write to it, for example C:\Users\your-username\Downloads
Please give it a try and let me know if the issue persists.
Luis
