6592 Discussions
Internal error in Model Optimizer Converter
rudakov__mikhail
I'm trying to convert a Tensorflow model into IR. The model Mask RCNN Inception V2 and I didn't modify it. After running MO I receive the following output:
[ ERROR ]  ----------------- INTERNAL ERROR ----------------
[ ERROR ]  Unexpected exception happened.
[ ERROR ]  Please contact Model Optimizer developers and forward the following information:
[ ERROR ]  0
[ ERROR ]  Traceback (most recent call last):
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\main.py", line 321, in main
    return driver(argv)
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\main.py", line 263, in driver
    mean_scale_values=mean_scale)
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\pipeline\tf.py", line 171, in
 tf2nx
    class_registration.apply_replacements(graph, class_registration.ClassType.FRONT_REPLACER)
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\utils\class_registration.py",
 line 102, in apply_replacements
    replacer.find_and_replace_pattern(graph)
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\front\tf\replacement.py", lin
e 50, in find_and_replace_pattern
    self.transform_graph(graph, desc._replacement_desc['custom_attributes'])
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\extensions\front\tf\ObjectDetect
ionAPI.py", line 359, in transform_graph
    last_node = Node(graph, op_output).in_node(0)
  File "C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\mo\graph\graph.py", line 267, in
 in_node
    return self.in_nodes()[key]
KeyError: 0
[ ERROR ]  ---------------- END OF BUG REPORT --------------
[ ERROR ]  -------------------------------------------------
The command used is below:
python ./mo_tf.py --input_model=C:\downloads\mask_rcnn_inception_v2_coco_2018_01_28.tar\mask_rcnn_inception_v2_coco_2018_01_28\frozen_inference_graph.pb   --tensorflow_use_custom_operations_config C:\Intel\computer_vision_sdk_2018.3.343\deployment_tools\model_optimizer\extensions\front\tf\mask_rcnn_support.json  --output="num_detections,detection_masks,detection_boxes,detection_classes,detection_scores" --tensorflow_object_detection_api_pipeline_config C:\downloads\mask_rcnn_inception_v2_coco_2018_01_28.tar\mask_rcnn_inception_v2_coco_2018_01_28\pipeline.config
Severine_H_Intel
Dear Mikhail,
it is the argument --output="num_detections,detection_masks,detection_boxes,detection_classes,detection_scores" which breaks the conversion, withdraw it and it will work.
Best,
Severine
