6620 Обсуждение
Is there a gRPC python script with SSL
Scuba
Начинающий
2 999Просмотр.
I was going through https://docs.openvino.ai/nightly/ovms_docs_deploying_server.html
Item 3
I updated the script predict.py so that it can work with SSL
I am getting this error
  File "//predict.py", line 4, in <module>
    from ovmsclient.generated import ovms_pb2, ovms_pb2_grpc
ModuleNotFoundError: No module named 'ovmsclient.generated'
(tutorial-env) root@ubuntu:/# cat predict.py
import numpy as np
from classes import imagenet_classes
import grpc
# Set up SSL/TLS credentials
credentials = grpc.ssl_channel_credentials()
# Create a secure channel to the gRPC server
channel = grpc.secure_channel("10.1.1.7:443", credentials)
# Create a gRPC stub
stub = ovms_pb2_grpc.OpenVinoModelServerStub(channel)
# Read image file
with open("zebra.jpeg", "rb") as f:
        img = f.read()
# Make prediction request to the specified model
request = ovms_pb2.PredictRequest()
request.inputs["0"].data = img
request.model_spec.name = "resnet"
# Send the request and get the response
response = stub.Predict(request)
# Handle the prediction output
if response:
    result_index = np.argmax(response.outputs["1"].data)
    predicted_class = imagenet_classes[result_index]
    print("Predicted class:", predicted_class)
else:
    print("No prediction output received.")
Метки (3)
0 баллов
4 Ответы
Wan_Intel
Модератор
2 928Просмотр.
Hi Scuba,
We'll further investigate the issue and we'll update you as soon as possible. On the other hand, could you please share the following information with us?
  • Which options did you choose to deploy the OpenVINO™ Model Server?
  • Which operating system are you using when deploying the OpenVINO™ Model Server?
Wan
Scuba
Начинающий
2 871Просмотр.
Container option :https://docs.openvino.ai/nightly/ovms_docs_deploying_server.html
AWS Ec2
Wan_Intel
Модератор
2 800Просмотр.
Hi Scuba,
Thanks for your patience.
I’ve deployed the OpenVINO™ Model Server in a Docker Container using the option that you shared hereI’ve validated the example from here that launched the OpenVINO™ Model Server with a ResNet50 image classification model from a cloud storage.
For your information, the error you encountered: ModuleNotFoundError: No module named ‘ovmsclient.generated’ when running from ovmsclient.generated import ovms_pb2, ovms_pb2_grpc is expected because the generated module is not available at ovmsclient package.
Sorry for the inconvenience and thank you for your support.
Wan
Wan_Intel
Модератор
2 487Просмотр.
Hi Scuba,
Thanks for your question.
If you need additional information from Intel, please submit a new question as this thread will no longer be monitored.
Wan​
Ответить
