6597 Discussions
Is there any limitation to output FIFO size (64?)
We are trying to run a network on Movidius with SDK2 . We are using the FIFO interface. We allocate FIFO with max size =100. We saw the following scenario: when we are inserting more than 64 elements without reading them we see that the output FIFO never had more than 64 elements- looks like there is some HW limitation to the size.
Is it true that output FIFO size is limited to 64?
@blinking The limit for a FIFO isn't supposed to be 64. This behavior is unintended and likely a bug. Thank you for reporting this!
