I did a
"make all"
in the folder
workspace/ncappzoo/tensorflow/inception_v3
This appeared in the terminal window.
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: compiletime version 3.4 of module 'tensorflow.python.framework.fast_tensor_util' does not match runtime version 3.5
return f(*args, *_kwds)
/usr/lib/python3.5/importlib/_bootstrap.py:222: RuntimeWarning: builtins.type size changed, may indicate binary incompatibility. Expected 432, got 412
return f(_args, **kwds)
WARNING:tensorflow:From /usr/local/lib/python3.5/dist-packages/tensorflow/contrib/learn/python/learn/datasets/base.py:198: retry (from tensorflow.contrib.learn.python.learn.datasets.base) is deprecated and will be removed in a future version.
Instructions for updating:
Use the retry module or similar alternatives.
and it looked like it stopped working. What does it mean?
- Tags:
- Tensorflow
@chicagobob123, please use https://github.com/movidius/ncappzoo/tree/master/tensorflow/inception instead of the inception_v3 project. Do a make VERSION=v3 to use inception_v3 model.
OK
FYI I used mobile net and found it to be pretty inaccurate for people who were more than a 20 feet away.
I would show you an example but I do not know where I can post an image.
The results were just OK. So I am going to try a heavier inference graph like InceptionV3
