6614 Discussions
LSTM Support in Openvino | Tensorflow and others.
pankajrawat
Does Openvino is fully compatible with RNN layers like LSTM, GRU etc, as openvino is explicitly targeting Computer vision Application.
As per official documentation of openvino supported layers.
https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Supported_Frameworks_Layers.html
Tensorflow - We dont find any LSTM, RNN layers mentioned - Below is one post which i raised and currently waiting for inputs
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/Keras-Tensorflow-backend-Lstm-Runtime-Error/m-p/1202578/highlight/false#M20382
Torch / Onnx- We do find GRU and LSTM mentioned in Onnx Supported layers - Below is one post which i raised and currently waiting for inputs
https://community.intel.com/t5/Intel-Distribution-of-OpenVINO/OpenVino-Pytorch-Error-LSTM/m-p/1201545
Can you please provide working examples and also comment on above posts if possible.
Labels (2)
Munesh_Intel
Hi Pankaj,
OpenVINO supports LSTM, GRU and RNN.
With regards to Model Optimizer, for ONNX framework, GRU and RNN are fully supported, whilst LSTM is supported with some limitations (Peepholes are not supported).
https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_Supported_Frameworks_Layers.html#onnx_supported_operators
And with regards to Inference Engine, more information is available at the following pages:
  • The Inference Engine header file, containing information about layers’ structure:
https://docs.openvinotoolkit.org/2020.4/ie__layers_8h_source.html
  • Variable setting in Inference Engine header file:
https://docs.openvinotoolkit.org/2020.4/ie__layers_8h.html#a4253a83f8170c0b540688fa5081d7947
  • The related Operations Specifications are given below:
    • LSTMCell
https://docs.openvinotoolkit.org/2020.4/openvino_docs_ops_sequence_LSTMCell_1.html
  • LSTMSequence
https://docs.openvinotoolkit.org/2020.4/openvino_docs_ops_sequence_LSTMSequence_1.html
  • GRUCell
https://docs.openvinotoolkit.org/2020.4/openvino_docs_ops_sequence_GRUCell_3.html
  • RNNCell
https://docs.openvinotoolkit.org/2020.4/openvino_docs_ops_sequence_RNNCell_3.html
Munesh
Munesh_Intel
Hi Pankaj,
    • LSTMCell
  • LSTMSequence
  • GRUCell
  • RNNCell
Munesh
Munesh_Intel
Hi Pankaj,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Munesh
