6575 Discussions
Loading reidentification network on GPU results in error
S__R
I tried loading FP16/face-reidentification-retail-0095.xml model onto GPU and I get this error:
[ ERROR ] program creation failed: implementation_map for N5cldnn4tileE could not find any implementation to match key
Any guidance as to what could be wrong? This is with stock smart classroom demo.
System information:
Intel(R) Core(TM) i7-7567U CPU @ 3.50GHz with iris GPU
Description:    Ubuntu 16.04.6 LTS
Kernel version: 4.15.0-45-generic
GPU driver is installed
OpenVino and plugin information
[ INFO ] InferenceEngine:
    API version ............ 1.4
    Build .................. 19154
[ INFO ] Loading plugin CPU
    API version ............ 1.5
    Build .................. lnx_20181004
    Description ....... MKLDNNPlugin
[ INFO ] Loading plugin GPU
    Description ....... clDNNPlugin
Bird__James
Having the Exact same issue, Can someone PLEASE reply
Shubha_R_Intel
Dear SR and Bird, James,
Kindly give us more details. How exactly are you loading it ? Are you running one of the OpenVino samples ?
Please post the exact command-line you tried. Also I hope you are using the latest OpenVino version 2019R1.1.
Shubha
