MULTI and HETERO
Wong__Jeremy
The Multi-Device plugin (MULTI) and the Heterogeneous plugin (HETERO) look similar. How should I choose?
Shubha_R_Intel
Dear Wong, Jeremy,
Good question. HETERO supports FPGA but not VPU while MULTI does not support FPGA but supports HDDL, so that is one distinguishing difference between the two. Multi-Device plugin automatically assigns inference requests to available computational devices to execute the requests in parallel.Heterogeneous plugin is more about assigning affinity (specific layers) to a preferred device with a fallback policy. HETERO's main job is to utilize accelerators power and calculate heaviest parts of network on accelerator and execute unsupported layers on fallback devices like CPU.
Hope it helps,
Shubha
Kenneth_C_Intel
I would look at the information of the pages
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_HETERO.html
and
https://docs.openvinotoolkit.org/latest/_docs_IE_DG_supported_plugins_MULTI.html
Honestly it depends on what you are trying to accomplish and how.
