MXNET ISSUE
Batra__Dhruv
Hey...I tried running the model optimizer on ssd_inceptionv3_512_voc0712trainval downloaded from the link which was provided in the documentation.
This is the Error I have got:
dhruv@dhruv:/opt/intel/computer_vision_sdk/deployment_tools/model_optimizer$ sudo pyt
hon3 mo_mxnet.py --input_model /home/dhruv/Downloads/ssd_inceptionv3_512_voc0712train
val/ssd_inceptionv3_512-0215.params --input_shape [1,3,300,300]
Model Optimizer arguments:
Common parameters:
- Path to the Input Model: /home/dhruv/Downloads/ssd_inceptionv3_512_voc
0712trainval/ssd_inceptionv3_512-0215.params
- Path for generated IR: /opt/intel/computer_vision_sdk_2018.5.445/dep
loyment_tools/model_optimizer/.
- IR output name: ssd_inceptionv3_512-0215
- Log level: ERROR
- Batch: Not specified, inherited from the model
- Input layers: Not specified, inherited from the model
- Output layers: Not specified, inherited from the model
- Input shapes: [1,3,300,300]
- Mean values: Not specified
- Scale values: Not specified
- Scale factor: Not specified
- Precision of IR: FP32
- Enable fusing: True
- Enable grouped convolutions fusing: True
- Move mean values to preprocess section: False
- Reverse input channels: False
MXNet specific parameters:
- Deploy-ready symbol file: None
- Enable MXNet loader for models trained with MXNet version lower than 1.0.0:
False
- Prefix name for args.nd and argx.nd files: None
- Pretrained model to be merged with the .nd files: None
- Enable saving built parameters file from .nd files: False
Model Optimizer version: 1.5.12.49d067a0
[ ERROR ]  Unexpected exception happened during extracting attributes for node mixed_
1_tower_1_conv_2_batchnorm_moving_mean.
Original exception message: Operation '_contrib_MultiBoxTarget' not supported. Please
register it as custom op.
For more information please refer to Model Optimizer FAQ (<INSTALL_DIR>/deployment_t
ools/documentation/docs/MO_FAQ.html), question #86.
