6614 Discussions
MYRIAD doesnot wirk on DL workbench , wind10
momo93
I installed  DL workbench on wind10 by using docker hub, the problem is that MYRIAD(neural compute stick ) is not detected by dl workbench, i have only cpu. and after that I installed it on linux (substym on wind10 ) and it was the same probem. so what i have to do please
Munesh_Intel
Hi Amcharlal,
Myriad plugin is not supported for DL Workbench on Windows 10. The information is provided in the link below:
https://docs.openvinotoolkit.org/2021.2/workbench_docs_Workbench_DG_Install_Workbench.html##minimum
For Linux version, only Ubuntu 18.04 LTS version is supported and have been validated.
You can get the related information here:
https://docs.openvinotoolkit.org/2021.2/workbench_docs_Workbench_DG_Install_Workbench.html#recommended
Windows Subsystem for Linux (WSL) meanwhile is just a terminal environment and doesn’t seem to include processing around USB. I would suggest you use DL Workbench in Ubuntu 18.04 LTS environment if you want to use MYRIAD plugin.
Munesh
Munesh_Intel
Hi Amcharlal,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Munesh
