6584 Discussions
MYRIAD plugin not building on Raspberry Pi 5 (64 bit)
SS03
Cannot setup MYRIAD for the OpenVINO toolkit installation for Intel NCS 2 in Raspberry Pi 5 (64 bit, VERSION="12 (bookworm)", VERSION_CODENAME=bookworm), these were the steps followed:
  • python3.9 -m venv ~/openvino_env
    source ~/openvino_env/bin/activate
  • python3.9 --version
  • pip install --upgrade pip
  • pip install openvino-dev
  • wget --no-check-certificate https://storage.openvinotoolkit.org/repositories/openvino/packages/2025.1/linux/openvino_toolkit_ubuntu20_2025.1.0.18503.6fec06580ab_arm64.tgz
  • tar -xf openvino_toolkit_ubuntu20_2025.1.0.18503.6fec06580ab_arm64.tgz
  • cd openvino_toolkit_ubuntu20_2025.1.0.18503.6fec06580ab_arm64
  • source ./setupvars.sh
  • echo "source ~/Desktop/OpenVINO/openvino_toolkit_ubuntu20_2025.1.0.18503.6fec06580ab_arm64/setupvars.sh" >> ~/.bashrc
  • source ~/.bashrc
  • sudo nano /etc/udev/rules.d/97-myriad-usbboot.rules
  • sudo udevadm control --reload-rules && sudo udevadm trigger
  • source ~/openvino_env/bin/activate
  • sudo usermod -a -G users $(whoami)
  • source ~/openvino/bin/setupvars.sh
  • python3 -c "from openvino.runtime import Core; print(Core().available_devices)"
  • This was the output faced on every occasion:
    DeprecationWarning: The openvino.runtime module is deprecated and will be removed in the 2026.0 release. Please replace openvino.runtime with openvino.
      warnings.warn(
    ['CPU']
  • (along with CPU, MYRIAD should also be seen in optimal situation)
Even after following the toolkit installation steps for toolkit 2023, 2022 versions, could not establish the MYRIAD connection. Any suggestions, structured release notes or documentations regarding this issue would be of great help.
SS03
@Zulkifli_Intel Any help would be appreciated.
AlHill
@SS03
It has only been 8 minutes.  Patience is needed.
[W10 is this generation's XP]
SS03
Just trying to reach out to more individuals for assistance, hence the mention.
AlHill
No need for that.  You will be responded to in time.
Zulkifli_Intel
SS03
For your information, OpenVINO™ toolkit 2025.1 releases no longer support Intel® Movidius™ VPU, including the Intel® Neural Compute Stick 2 (Intel® NCS2).
The latest supported OpenVINO™ release for Movidius™ VPU is the 2022.3.2 LTS, as mentioned in the 'Major Features and Improvements Summary' section in the OpenVINO™ Toolkit 2022.3 LTS Release Notes page. You can download the OpenVINO™ 2022.3.2 LTS here.
Zul
Zulkifli_Intel
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
