6597 Discussions
Mask R-CNN Inception ResNet V2 1024x1024 Conversion
Silviu1
Hi, I have trained and saved my own TF2 Mask RCNN model. I am trying to optimize the saved_model.pb for faster inference. I first try to convert the model into a frozen graph as states here https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Mode... but i get this error tensorflow.python.framework.errors_impl.InternalError: Tensorflow type 21 not convertible to numpy dtype. Exception occurred during running replacer "REPLACEMENT_ID" (<class 'extensions.middle.PartialInfer.PartialInfer'>): Stopped shape/value propagation at "StatefulPartitionedCall/map/TensorArrayV2_2" node. What can i do?
Iffa_Intel
If possible can you share/attach your model files here?.
Sincerely,
Iffa
Silviu1
The files are too big so i am attaching this link from wetransfer. You can find the saved model.pb as well as the last checkpoint that i have used to export this model. https://wetransfer.com/downloads/dc095bd9e7e55351c164d272720a54d020210722074104/ab9b6f08cde6d620cb142b32388a1fb320210722074133/11f3e7
Thank you for the response
Iffa_Intel
Thanks & Noted.
We are investigating this and will get back to you as soon as possible
Sincerely,
Iffa
Iffa_Intel
I had tested your model and I get the same output.
I believe this is because you didn't freeze your model.
Please help to freeze your model before converting it.
You may refer here: https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html#freeze-the-tensorflow-model
Sincerely,
Iffa
Silviu1
Good morning,
1. The model is not frozen indeed.
2. This is the problem we already talking about https://docs.openvinotoolkit.org/latest/openvino_docs_MO_DG_prepare_model_convert_model_Convert_Model_From_TensorFlow.html#freeze-the-tensorflow-model  . The commnad to freeze the model according to this link is  python3 mo_tf.py --saved_model_dir <SAVED_MODEL_DIRECTORY> --output_dir <OUTPUT_MODEL_DIR> .
3. The point is that following the exact steps in the guides provided you run from error to error and eventually can't convert the TF2 saved models.
4. What can we do to have this working as expected? I am happy to work together for a solution.
Silviu
Iffa_Intel
In addition to that, your model might have some unsupported operation which this issue had been captured before.
For OpenVINO toolkit, this issue is potentially fixed in the 2022.1 version soon.
If you are willing to build the OpenVINO package from source, you could try to use your model with it, which the latest github release might already fix this issue.
This is the link to the official OpenVINO github: https://github.com/openvinotoolkit/openvino
Sincerely,
Iffa
Silviu1
I will consider at this suggestion.
Thank you !
Silviu
Iffa_Intel
Splendid!
Shall I proceed with the closure of this thread then? if you don't have any other inquiries.
Sincerely
Iffa
Iffa_Intel
Intel will no longer monitor this thread since this issue has been resolved. If you need any additional information from Intel, please submit a new question.
Sincerely,
Iffa
