Mask RCNN demo usage
hqx627
Following this link Convert ONNX* Mask R-CNN Model to the Intermediate Representation , I get mask_rcnn_R_50_FPN_1x.xml and then choose DetectionOutput for the detection_output_name.
https://docs.openvinotoolkit.org/latest/omz_models_model_yolact_resnet50_fpn_pytorch.htmlhttps://docs.openvinotoolkit.org/latest/omz_models_model_yolact_resnet50_fpn_pytorch.html
But when I run the demo with DetectionOutput, I got an error:
mask_rcnn_demo.exe -i D:/hqx/yolact/test_Color.jpg -m  D:/hqx/mask_rcnn_R_50_FPN_1x.xml -detection_output_name=DetectionOutput
InferenceEngine:        API version ......... 2.1
        Build ........... 2021.3.0-2787-60059f2c755-releases/2021/3
[ INFO ] Parsing input parameters
[ INFO ] Files were added: 1
[ INFO ]     D:/hqx/yolact/test_Color.jpg
[ INFO ] Loading Inference Engine
[ INFO ] Device info:
[ INFO ]        CPU
        MKLDNNPlugin version ......... 2.1
[ INFO ] Loading network files
[ INFO ] Preparing input blobs
[ INFO ] Network batch size is 1
[ INFO ] Prepare image D:/hqx/yolact/test_Color.jpg
[ INFO ] Preparing output blobs
[ INFO ] Loading model to the device
[ INFO ] Create infer request
[ INFO ] Setting input data to the blobs
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\parallel\registry_parallel.impl.hpp (90) cv::parallel::ParallelBackendRegistry::ParallelBackendRegistry core(parallel): Enabled backends(3, sorted by priority): ONETBB(1000); TBB(990); OPENMP(980)
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Program Files (x86)\Intel\openvino_2021.3.394\opencv\bin\opencv_core_parallel_onetbb452_64d.dll => FAILED
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load opencv_core_parallel_onetbb452_64d.dll => FAILED
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (67) cv::plugin::impl::DynamicLib::libraryLoad load C:\Program Files (x86)\Intel\openvino_2021.3.394\opencv\bin\opencv_core_parallel_tbb452_64d.dll => OK
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\parallel\plugin_parallel_wrapper.impl.hpp (48) cv::impl::PluginParallelBackend::initPluginAPI core(parallel): plugin is ready to use 'TBB (interface 9107) OpenCV parallel plugin'
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\include\opencv2/core/parallel/backend/parallel_for.tbb.hpp (54) cv::parallel::tbb::ParallelForBackend::ParallelForBackend Initializing TBB parallel backend: TBB_INTERFACE_VERSION=9107
[ INFO:0] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\parallel\parallel.cpp (73) cv::parallel::createParallelForAPI core(parallel): using backend: TBB (priority=990)
[ INFO ] Start inference
[ INFO ] Processing output blobs
[ ERROR ] Cannot find blob with name: DetectionOutput
C:\j\workspace\private-ci\ie\build-windows-vs2019@2\b\repos\openvino\inference-engine\src\mkldnn_plugin\mkldnn_infer_request.cpp:293
C:\Program Files (x86)\Intel\openvino_2021\deployment_tools\inference_engine\include\details/ie_exception_conversion.hpp:66
[ INFO:1] global C:\jenkins\workspace\OpenCV\OpenVINO\2021.3\build\windows\opencv\modules\core\src\utils\plugin_loader.impl.hpp (74) cv::plugin::impl::DynamicLib::libraryRelease unload C:\Program Files (x86)\Intel\openvino_2021.3.394\opencv\bin\opencv_core_parallel_tbb452_64d.dll
 run the demo with 6849/sink_port_0, still got an error:
mask_rcnn_demo.exe -i D:/hqx/yolact/test_Color.jpg -m  D:/hqx/mask_rcnn_R_50_FPN_1x.xml -detection_output_name=6849/sink_port_0
[ INFO ]        CPU
[ ERROR ] Cannot add output! Layer 6849/sink_port_0 wasn't found!
What is the problem? How should I do?
(Attachment file is mask rcnn demo source code)
Vladimir_Dudnik
please note, each and every Open Model Zoo demo contain models.lst file, which lists Open Model Zoo models that demo support and additionally, you may use this file as a parameter to Open Model Zoo Model Downloader, to download (and convert to IR, if necessary) models supported by this demo.
  Vladimir
Wan_Intel
Hi Hqx627,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Wan
