6597 Discussions
Message type "caffe.LayerParameter" has no field named "permute_param".
Hi, I'm trying to compile a MobileNetSSD that is working find with OpenCV 3.3.0. name: "MobileNet-SSD" input: "data" input_shape { dim: 1 dim: 3 dim: 300 dim: 300 } layer { name: "conv0" type: "Convolution" bottom: "data" top: "conv0" param { lr_mult: 1.0 decay_mult: 1.0 } param { lr_mult: 2.0 decay_mult: 0.0 } convolution_param { num_output: 32 pad: 1 kernel_size: 3 stride: 2 weight_filler { type: "msra" } bias_filler { type: "constant" value: 0.0 } } } ....... layer { name: "conv13_mbox_loc_perm" type: "Permute" bottom: "conv13_mbox_loc" top: "conv13_mbox_loc_perm" permute_param { order: 0 order: 2 order: 3 order: 1 } } layer { name: "conv13_mbox_loc_flat" type: "Flatten" bottom: "conv13_mbox_loc_perm" top: "conv13_mbox_loc_flat" flatten_param { axis: 1 } } layer { name: "conv13_mbox_conf" type: "Convolution" bottom: "conv13" top: "conv13_mbox_conf" param { lr_mult: 1.0 decay_mult: 1.0 } param { lr_mult: 2.0 decay_mult: 0.0 } convolution_param { num_output: 126 kernel_size: 1 weight_filler { type: "msra" } bias_filler { type: "constant" value: 0.0 } } } ................... layer { name: "conv17_2_mbox_loc" type: "Convolution" bottom: "conv17_2" top: "conv17_2_mbox_loc" param { lr_mult: 1.0 decay_mult: 1.0 } param { lr_mult: 2.0 decay_mult: 0.0 } convolution_param { num_output: 24 kernel_size: 1 weight_filler { type: "msra" } bias_filler { type: "constant" value: 0.0 } } } layer { name: "conv17_2_mbox_loc_perm" type: "Permute" bottom: "conv17_2_mbox_loc" top: "conv17_2_mbox_loc_perm" permute_param { order: 0 order: 2 order: 3 order: 1 } } layer { name: "conv17_2_mbox_loc_flat" type: "Flatten" bottom: "conv17_2_mbox_loc_perm" top: "conv17_2_mbox_loc_flat" flatten_param { axis: 1 } } layer { name: "conv17_2_mbox_conf" type: "Convolution" bottom: "conv17_2" top: "conv17_2_mbox_conf" param { lr_mult: 1.0 decay_mult: 1.0 } param { lr_mult: 2.0 decay_mult: 0.0 } convolution_param { num_output: 126 kernel_size: 1 weight_filler { type: "msra" } bias_filler { type: "constant" value: 0.0 } } } layer { name: "conv17_2_mbox_conf_perm" type: "Permute" bottom: "conv17_2_mbox_conf" top: "conv17_2_mbox_conf_perm" permute_param { order: 0 order: 2 order: 3 order: 1 } } layer { name: "conv17_2_mbox_conf_flat" type: "Flatten" bottom: "conv17_2_mbox_conf_perm" top: "conv17_2_mbox_conf_flat" flatten_param { axis: 1 } } layer { name: "conv17_2_mbox_priorbox" type: "PriorBox" bottom: "conv17_2" bottom: "data" top: "conv17_2_mbox_priorbox" prior_box_param { min_size: 285.0 max_size: 300.0 aspect_ratio: 2.0 aspect_ratio: 3.0 flip: true clip: false variance: 0.1 variance: 0.1 variance: 0.2 variance: 0.2 offset: 0.5 } } layer { name: "mbox_loc" type: "Concat" bottom: "conv11_mbox_loc_flat" bottom: "conv13_mbox_loc_flat" bottom: "conv14_2_mbox_loc_flat" bottom: "conv15_2_mbox_loc_flat" bottom: "conv16_2_mbox_loc_flat" bottom: "conv17_2_mbox_loc_flat" top: "mbox_loc" concat_param { axis: 1 } } layer { name: "mbox_conf" type: "Concat" bottom: "conv11_mbox_conf_flat" bottom: "conv13_mbox_conf_flat" bottom: "conv14_2_mbox_conf_flat" bottom: "conv15_2_mbox_conf_flat" bottom: "conv16_2_mbox_conf_flat" bottom: "conv17_2_mbox_conf_flat" top: "mbox_conf" concat_param { axis: 1 } } layer { name: "mbox_priorbox" type: "Concat" bottom: "conv11_mbox_priorbox" bottom: "conv13_mbox_priorbox" bottom: "conv14_2_mbox_priorbox" bottom: "conv15_2_mbox_priorbox" bottom: "conv16_2_mbox_priorbox" bottom: "conv17_2_mbox_priorbox" top: "mbox_priorbox" concat_param { axis: 2 } } layer { name: "mbox_conf_reshape" type: "Reshape" bottom: "mbox_conf" top: "mbox_conf_reshape" reshape_param { shape { dim: 0 dim: -1 dim: 21 } } } layer { name: "mbox_conf_softmax" type: "Softmax" bottom: "mbox_conf_reshape" top: "mbox_conf_softmax" softmax_param { axis: 2 } } layer { name: "mbox_conf_flatten" type: "Flatten" bottom: "mbox_conf_softmax" top: "mbox_conf_flatten" flatten_param { axis: 1 } } layer { name: "detection_out" type: "DetectionOutput" bottom: "mbox_loc" bottom: "mbox_conf_flatten" bottom: "mbox_priorbox" top: "detection_out" include { phase: TEST } detection_output_param { num_classes: 21 share_location: true background_label_id: 0 nms_param { nms_threshold: 0.45 top_k: 100 } code_type: CENTER_SIZE keep_top_k: 100 confidence_threshold: 0.25 } } and I'm getting this error: vladi@vladi:~/workspace/ncsdk/examples/caffe/real-time-object-detection$ mvNCCompile MobileNetSSD_deploy.prototxt -s 12 mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 [libprotobuf ERROR google/protobuf/text_format.cc:298] Error parsing text-format caffe.NetParameter: 1177:17: Message type "caffe.LayerParameter" has no field named "permute_param". WARNING: Logging before InitGoogleLogging() is written to STDERR F1026 17:50:53.770750 32253 upgrade_proto.cpp:88] Check failed: ReadProtoFromTextFile(param_file, param) Failed to parse NetParameter file: MobileNetSSD_deploy.prototxt *** Check failure stack trace: *** Aborted (core dumped) I'm using latest SDK updated and compiled today. vladi@vladi:~/workspace/ncsdk$ git pull Already up-to-date. my PYTHONPATH and version vladi@vladi:~/workspace/ncsdk$ python --version Python 2.7.13 vladi@vladi:~/workspace/ncsdk$ echo $PYTHONPATH :/opt/movidius/caffe/python vladi@vladi:~/workspace/ncsdk$ I'm running Ubuntu Desktop 17.04 Linux vladi 4.10.0-37-generic #41-Ubuntu SMP Fri Oct 6 20:20:37 UTC 2017 x86_64 x86_64 x86_64 GNU/Linux Could you help me to understand what I'm doing wrong? Sebastian
@ssalomo1 You aren't doing anything wrong. The current SDK (1.09.00) doesn't support some of the layers required by this network (permute, priorbox, detectionoutput, flatten). Support for these layers is something we are looking into for a future release.
Hi Tome,
Thanks for your answer, I'll wait for future releases to use this network.
In meantime, what is the supported network you can recommend me to do object detection?
Sebastian.
@ssalomo1 In regards to object detection, you can check out the recently released Tiny Yolo example on the app zoo by visiting: https://ncsforum.movidius.com/discussion/345/tinyyolo-object-detection-example-is-now-in-the-ncappzoo-repository#latest . Also @dagoff has his version working at https://ncsforum.movidius.com/discussion/218/tiny-yolo-on-ncs. He has the project hosted on his github: https://github.com/gudovskiy/yoloNCS
Thank you very much.
Waiting for a future release to solve this problem.
So I am having the same issue that you guys experienced around 8 months ago… I am using the NCSDK 2… I watched Ashwin's last webinar and pretty sure he showed MobileNet SSD…
pls advise!
