Using retrain MobileNet-SSD's problems
Hi, I am try to using retrained MobileNet-SSD model, there have some problems! The retrained was fetched on https://github.com/zeusees/SSD_License_Plate_Detection.
I merge the bn by merge_bn.py and rewrite the conf name to remove "_new" by my own script (https://github.com/zhoujustin/MobileNetSSD_Tools/blob/master/mobssd_rm_new.py).
When I using the caffe.net, I can get the result. BUT mvNCCompile the model and weight, the result always return NAN. How can I debug it?
The coverted caffemodel prototxt and graph can be found in my google drive(https://drive.google.com/file/d/1wMQWSN4zfDPaXXEuF4BlmsLJvNvCIWxk/view?usp=sharing)
@Zhoustin Hi, I'm having some problems compiling and checking your provided files.
WARNING: Logging before InitGoogleLogging() is written to STDERR F0403 13:39:33.733206 9083 blob.cpp:507] Check failed: count_ == proto.data_size() (864 vs. 0) *** Check failure stack trace: *** Aborted (core dumped)
Can you please double check your caffe and weights file and send me another link?
Sorry for the model which compiled on the jetson TX platform.
I redo it on my pc and there is the link(https://drive.google.com/open?id=1xNGQbszsFmAv4Npk02QV5adDqyVHMLQX)
Appreciate for your reply!
@Zhoujustin It looks like some of the values from the conv2 layer are nearing the limit of fp16.
Result: (128, 160, 120)
1) 426420 nan
2) 1707207 nan
3) 1707198 nan
4) 1707197 nan
5) 1707196 nan
Expected: (128, 160, 120)
1) 1896613 62300.0
2) 1896012 62240.0
3) 1882207 62200.0
4) 1893698 61950.0
5) 1887356 60960.0
I'll keep digging. Will keep you posted.
Thanks for your digging. We look forward to good news.
@Zhoujustin The prototxt file uses the same layer names for multiple top and bottom parameters. Our compiler doesn't seem to like that so I made some adjustments (i.e. unique top name for each Conv/BatchNorm/Scale, & same bottom/top name for Relus).
The input size is pretty large and I get nans if I run the graph, so I reduced the size of the input to 320 x 240 and it runs to the end (no more nans in conv2 layer also), but it results in invalid classification results. In order to get valid classification results, I think you may need to retrain the network with a smaller size.
You can view the edited prototxt file here.
Thank you for your reply, I probably understand your revised content, I read the discussion on the issue of mobile net-ssd above 300 pixels image, I hope this problem can be resolved sooner.
@Tome_at_Intel I'm retrain another graph with 300X300 model. This train detected the bread. The result was as same as above. I already using the prototxt you edited.
I already test the model in caffe, it worked well. But in the movidius it always return [ 1.000e+00 -1.882e-04 -1.346e-02 … -8.743e-03 1.944e-02 -2.725e+04].
Please give me some suggestions. Thanks.
link: https://drive.google.com/file/d/19bG-YTM-cYLzmb5SFgSpNez-SLR2CHgn/view?usp=sharing
The prototxt's input dim should be changed to 300 x 300. Sorry for it.
@Zhoujustin Okay, I'll test it out with the new dims and let you know. Thanks.
@Tome_at_Intel I found the problems. Because of the nvcaffe not the as ssd-caffe. When I changed into the ssd-caffe, there are no problems. All the model seems work well.
Thanks for your attention.
@Zhoujustin Glad you were able to solve the problem.
@Tome_at_Intel Thanks, Hope the anothers will avoid this 'bug'.
@Zhoujustin, could you explain in detail how to fix it, i met the same problem
@voqtuyen Using the https://github.com/chuanqi305/MobileNet-SSD, and https://github.com/weiliu89/caffe/tree/ssd. Don't using the other version.
