Missed header file onnx/onnx-ml.pb.h
redradist
Hi all,
I've faced with issue that:
~/Projects/OpenVINO/cmake-build-debug/_deps/ext_onnx-src/onnx/onnx_pb.h:50:10: fatal error: onnx/onnx-ml.pb.h: No such file or directory
Here is my options:
-DVERBOSE_BUILD=ON -DENABLE_TEMPLATE_PLUGIN=ON -DCMAKE_BUILD_TYPE=Debug -DENABLE_PYTHON=ON -DPYTHON_EXECUTABLE=/usr/local/bin/python3 -DENABLE_WHEEL=ON -DENABLE_TESTS=ON -DENABLE_FASTER_BUILD=ON -DONNX_ML=1 -DIE_EXTRA_MODULES=${OPENVINO_CONTRIB_REPO_DIR}/modules
Seems like onnx should be built during compile time `~/Projects/OpenVINO/cmake-build-debug/_deps/ext_onnx-src` because cmake download sources from the git repo ...
Seems like this issue is that `~/Projects/OpenVINO/cmake-build-debug/_deps/ext_onnx-src` not compiled before main target
Maybe I missed some option ?
Iffa_Intel
Greetings,
First of all, it is recommended for you to use the latest OpenVINO version 2021.3 and refer to the wiki section from the link I provide below.
Build the OpenVINO from source correctly according to your OS:
https://github.com/openvinotoolkit/openvino/wiki
Make sure you could successfully build it (means all pre-requisite had been installed & setup correctly)
I had attached the successfully OpenVINO 2021.3 built from source & I'm using Ubuntu 18.04
My steps are the same as this guide: https://github.com/openvinotoolkit/openvino/wiki/BuildingForLinux
NOTE: make sure you are using CMake* 3.13 or higher
Sincerely,
Iffa
Iffa_Intel
Greetings,
Intel will no longer monitor this thread since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Sincerely,
iffa
