6595 Discussions
Missing attribute (storageOrder) error when compiling a simple Tensorflow model
I am trying to build a simple Tensorflow model and compile it for Movidius NCS, but I am running into errors and documentation is not helpful.
Code producing the model files:
#!/usr/bin/python3 import tensorflow as tf if __name__ == '__main__': input_data = tf.placeholder(tf.float32, (10, 10), name='input') two = tf.get_variable('two', initializer=2.0) output_data = tf.multiply(2.0, input_data, name='output') saver = tf.train.Saver() with tf.Session() as session: session.run(tf.global_variables_initializer()) saver.save(session, '/tmp/test.tf')
After running it, these files are produced:
$ ls /tmp/test.tf* /tmp/test.tf.data-00000-of-00001 /tmp/test.tf.index /tmp/test.tf.meta
Compilation with errors:
$ mvNCCompile /tmp/test.tf.meta -o /tmp/test.tf.movidius mvNCCompile v02.00, Copyright @ Movidius Ltd 2016 /usr/local/bin/ncsdk/Controllers/TensorFlowParser.py:149: DeprecationWarning: invalid escape sequence \d return re.sub(':\d+', '', word) /home/jirka/.local/lib/python3.6/site-packages/tensorflow/python/pywrap_tensorflow_internal.py:15: DeprecationWarning: the imp module is deprecated in favour of importlib; see the module's documentation for alternative uses import imp /home/jirka/.local/lib/python3.6/site-packages/tensorflow/python/util/tf_inspect.py:45: DeprecationWarning: inspect.getargspec() is deprecated, use inspect.signature() or inspect.getfullargspec() if d.decorator_argspec is not None), _inspect.getargspec(target)) Traceback (most recent call last): File "/usr/local/bin/mvNCCompile", line 118, in <module> create_graph(args.network, args.inputnode, args.outputnode, args.outfile, args.nshaves, args.inputsize, args.weights) File "/usr/local/bin/mvNCCompile", line 108, in create_graph net.optimize() File "/usr/local/bin/ncsdk/Models/Network.py", line 197, in optimize self.convert_network_input_to_yxz() File "/usr/local/bin/ncsdk/Models/Network.py", line 229, in convert_network_input_to_yxz if self.storageOrder.value == StorageOrder.orderYXZ.value: AttributeError: 'Network' object has no attribute 'storageOrder'
Changing shape of input_data to (1, 10, 10) or (1, 1, 10, 10), (1, 10, 10, 1) or (10, 10, 1) does not make any difference.
Tensorflow: 1.3.0 (I tried with 1.4.0 too. It gives more deprecation warnings, but does not affect the NCSDK error.)
NCSDK: 1.10.01.00 (According to /opt/movidius/version.txt. It does not match what mvNCCompile prints. Freshly installed.)
Any advice how to deal with it or fixes in NCSDK, if the problem is there, welcome. Thanks!
Jirka
@jirka Thanks for bringing this to our attention. We are looking into this issue at the moment and I will let you know as soon as we find the root cause. Thank you for your patience.
is there any fix or workaround for this issue ?
Thanks !
