6584 Discussions
Using mobilenet trained network to run in NCS
This is the error I get when I'm trying to generate a NCS graph.
As node.type is "Relu6"
File "/usr/local/bin/ncsdk/Controllers/TensorFlowParser.py", line 739, in parse_tensor
prev_node.postOp = StageType.relu_x
AttributeError: 'NoneType' object has no attribute 'postOp'
Please guide me here
@stopcharla Which network are your experiencing this issue with? Please provide the steps to reproduce your issue you mentioned and a link to the network so that I can help you to debug the error.
I used the tensorflow's retrain.py to train a gender classifier using mobilenet_1.0_224 architecture, then i tried to convert the graph to ncs compatible. This where i came across this issue.
@stopcharla Can you provide a link to your model? This would save me a lot of time. Thanks.
https://drive.google.com/open?id=1QPVmjvv2X4N3s23yfaQA8i42Dn-MJ9I5
Command used to compile:
mvNCCompile ~/Downloads/pet_model.pb -s 12 -in=MobilenetV1/MobilenetV1/Conv2d_0/convolution -on=final_result -o pet.graph
@stopcharla It seems I don't have access to this model. Can you give me access to download this model?
