Missing deployment_tools/inference_engine/python_api
Guobin_Z_Intel
According to the document, there is a preview version of the Inference Engine Python* API for evaluation purpose only. But I cannot find the directory in my download, could you help tell me how to access the Python stuff? Thanks!
Seunghyuk_P_Intel
Hi Guobin,
I'm not sure which version of OpenVINO you have.
I have 2018.1.265.
It is providing python_api in /deployment_tools/inference_engine/python_api.
And also there are python samples in /deployment_tools/inference_engine/samples/python_samples.
Peter.
smith__raphael
I can't found the folder too : deployment_tools/inference_engine/python_api
but I have the python samples. I'm using 2018.3.343 version.
I don't know know how to install the older version.
Any idea to help me pls ? Thanks.
Monique_J_Intel
Hi Raphael,
If you are looking for python api documentation it is here.If you are wondering how to use the python samples you can use the -h command line argument to see the helper menu that will show you what command arguments are required to run the sample.
Kind Regards,
Monique Jones
Mikhail_T_Intel
Hi everyone,
Starting from OpenVINO R3 python bindings for Inference Engine are moved too <INSTALL_DIR>/python/<target_python_version> since this folder now contains not only bindings for Inference Engine but also for OpenCV included to OpenVINO package.
Samples location is the same ./deployment_tools/inference_engine/samples/python_samples.
BTW, to not worry about packages location and to simplify environment setting process I recommend to use setupvars script as described in 'Setting Up the Environment' section of the docs which Monique mentioned above.
