Missing xml file after demo build
esteev
Even if I run the -h command for any build, it shows missing XML error.
[ ERROR ] Error loading XML file: C:\Users\Suryank\Documents\Intel\OpenVINO\omz_demos_build\intel64\Release\plugins.xml:1:0: File was not found
This persists even if I provide path for input files and model.xml
Vladimir_Dudnik
seems something is wrong with your OpenVINO installation. The file plugins.xml should be located at "C:\Program Files (x86)\IntelSWTools\openvino_2021.1.110\deployment_tools\inference_engine\bin\intel64\Release\plugins.xml"
It is part of OpenVINO binary package and not the result of Open Model Zoo demo build.
  Vladimir
IntelSupport
Community Manager
Hi Esteev,
Thanks for reaching out.
When we tried out from our end, it worked without these errors. Can you please try to run the demo_security_barrier_camera.bat demo? Did you get the same error?
If so, the issue might due to incomplete OpenVINO installation and you will need to reinstall and make sure to follow all the installation steps carefully.
Aznie
IntelSupport
Community Manager
Hi Esteev,
This thread will no longer be monitored since we have provided a solution. If you need any additional information from Intel, please submit a new question.
Aznie
