MobileNet support and Group Convolutions
Hello, I tried to use MobileNet from here and looks like there is a problem with supporting group convolutions defined below. Could you test it and fix compiler in future release?
layer {
type: "Convolution"
bottom: "conv1"
top: "conv2_1/dw"
convolution_param {
num_output: 32
bias_term: false
pad: 1
kernel_size: 3
group: 32
stride: 1
The model from here works well
@csarron , thanks I'll check
