MobileNet_v2 Support for NCS
员工
1,647 次查看
Any plan to support Tensorflow MobileNet_V2 for NCS ???
0 项奖励
6 回复数
员工
1,426 次查看
@rado_rado Thank you for bringing this up. We don't have any plans to support this network yet, but we value each and every one of your requests. Let's open up a poll and ask how many users would like to see support for this network.
0 项奖励
员工
1,426 次查看
I think it's already supported @rado_rado , I can successfully run MobileNet V2 for the models here: https://github.com/tensorflow/models/blob/master/research/slim/nets/mobilenet/README.md
0 项奖励
员工
1,426 次查看
Hi @csarron .
I was trying to compile graph from MobileNet V2. To do that I've modified Make file from V1 for V2 and getting following error on Freezing model step: "Unable to read file (mobilenet_v2_1.0_224.ckpt.index). Perhaps the file is corrupt or was produced by a newer version of TensorFlow with format changes (failed to seek to header entry): corrupted compressed block contents".
File mobilenet_v2_1.0_224.ckpt.index is present in the model
Looks like you did not have this issue. Could you please post your Make file.
Thank you in advance
0 项奖励
员工
1,426 次查看
Found the issue: mobilenet_v2 index files created with compression. At the same time installed tensorflow 1.4 does not support compressed headers.
Upgrade to tf 1.5 resolved the issue.
0 项奖励
员工
1,426 次查看
@vgor even I had this compression related issue. Did you upgrade to tf1.5 using pip or you compiled it from sources ???
0 项奖励
员工
1,426 次查看
@rado_rado - I've used pip for upgrade
0 项奖励
回复
