MobileNetssd error
first layer output no problem
mvNCCheck -w MobileNetSSD_deploy_compress.caffemodel -is 416 416 -i "/home/he/deeplearn/caffe/mobilev2ssd/caffe-ssd_3/data/Peddevkit/PED/JPEGImages/1527485592703wc-20180521-000232.jpg" MobileNetSSD_deploy_compress.prototxt -on conv1 -cs 0,1,2
mvNCCheck v02.00, Copyright @ Movidius Ltd 2016
/usr/local/lib/python3.5/dist-packages/skimage/transform/_warps.py:84: UserWarning: The default mode, 'constant', will be changed to 'reflect' in skimage 0.15.
warn("The default mode, 'constant', will be changed to 'reflect' in "
/usr/local/bin/ncsdk/Controllers/FileIO.py:52: UserWarning: You are using a large type. Consider reducing your data sizes for best performance
"Consider reducing your data sizes for best performance\033[0m")
USB: Transferring Data…
USB: Myriad Execution Finished
USB: Myriad Connection Closing.
USB: Myriad Connection Closed.
Result: (64, 208, 208)
1) 1345170 69.4
2) 1380160 67.6
3) 1344990 67.4
4) 1345198 66.9
5) 1381180 66.5
Expected: (64, 208, 208)
1) 1345170 69.25
2) 1380160 67.7
3) 1344990 67.4
4) 1345198 66.94
5) 1381180 66.44
Obtained values
Obtained Min Pixel Accuracy: 0.25947652757167816% (max allowed=2%), Pass
Obtained Average Pixel Accuracy: 0.007905358506832272% (max allowed=1%), Pass
Obtained Percentage of wrong values: 0.0% (max allowed=0%), Pass
Obtained Pixel-wise L2 error: 0.014139951858627453% (max allowed=1%), Pass
Obtained Global Sum Difference: 15158.2119140625
but second layer output error
mvNCCheck -w MobileNetSSD_deploy_compress.caffemodel -is 416 416 -i "/home/he/deeplearn/caffe/mobilev2ssd/caffe-ssd_3/data/Peddevkit/PED/JPEGImages/1527485592703wc-20180521-000232.jpg" MobileNetSSD_deploy_compress.prototxt -on conv2 -cs 0,1,2
Result: (128, 104, 104)
1) 240215 nan
2) 954058 nan
3) 954065 nan
4) 402449 nan
5) 650229 nan
Expected: (128, 104, 104)
1) 1164665 37.2
2) 1166330 34.88
3) 1164769 34.4
4) 1162714 33.38
5) 1162610 32.16
/home/he/.local/lib/python3.5/site-packages/numpy/core/_methods.py:26: RuntimeWarning: invalid value encountered in reduce
return umr_maximum(a, axis, None, out, keepdims)
/usr/local/bin/ncsdk/Controllers/Metrics.py:75: RuntimeWarning: invalid value encountered in greater
diff)) / total_values * 100
Obtained values
Obtained Min Pixel Accuracy: nan% (max allowed=2%), Fail
Obtained Average Pixel Accuracy: nan% (max allowed=1%), Fail
Obtained Percentage of wrong values: 53.2986432137574% (max allowed=0%), Fail
Obtained Pixel-wise L2 error: nan% (max allowed=1%), Fail
Obtained Global Sum Difference: nan
secnd layer is
layer {
type: "Convolution"
bottom: "conv1"
top: "conv2/dw"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 64
bias_term: true
pad: 1
kernel_size: 3
stride: 2
group: 64
engine: CAFFE
weight_filler {
type: "msra"
layer {
type: "ReLU"
bottom: "conv2/dw"
top: "conv2/dw"
layer {
type: "Convolution"
bottom: "conv2/dw"
top: "conv2"
param {
lr_mult: 1.0
decay_mult: 1.0
convolution_param {
num_output: 128
bias_term: true
kernel_size: 1
weight_filler {
type: "msra"
layer {
type: "ReLU"
bottom: "conv2"
top: "conv2"
May it's input size is too big cause this problem ?
@hexianyqan Others have experienced a similar issue. https://ncsforum.movidius.com/discussion/comment/1720/#Comment_1720. We are currently looking into this issue. Thanks.
