Model Optimizer Error
Rushikesh_P_Intel
Model Optimizer arguments:
Common parameters:
               - Path to the Input Model:                /home/macnica/Desktop/bkav_pretrained_model/frozen_inference_graph.pb
               - Path for generated IR:                /opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/.
               - IR output name:            frozen_inference_graph
               - Log level:          ERROR
               - Batch:                Not specified, inherited from the model
               - Input layers:    Not specified, inherited from the model
               - Output layers:                Not specified, inherited from the model
               - Input shapes:   [1,1,1,3]
               - Mean values:   Not specified
               - Scale values:    Not specified
               - Scale factor:     Not specified
               - Precision of IR:               FP32
               - Enable fusing: True
               - Enable grouped convolutions fusing:     True
               - Move mean values to preprocess section:          False
               - Reverse input channels:             True
TensorFlow specific parameters:
               - Input model in text protobuf format:    False
               - Offload unsupported operations:           False
               - Path to model dump for TensorBoard: None
               - List of shared libraries with TensorFlow custom layers implementation:               None
               - Update the configuration file with input/output node names:    None
               - Use configuration file used to generate the model with Object Detection API:    None
               - Operations to offload: None
               - Patterns to offload:      None
               - Use the config file:        None
Model Optimizer version:             1.5.12.49d067a0
/opt/intel/computer_vision_sdk_2018.5.455/deployment_tools/model_optimizer/mo/ops/slice.py:111: FutureWarning: Using a non-tuple sequence for multidimensional indexing is deprecated; use `arr[tuple(seq)]` instead of `arr[seq]`. In the future this will be interpreted as an array index, `arr[np.array(seq)]`, which will result either in an error or a different result.
  value = value[slice_idx]
[ ERROR ]  Shape is not defined for output 0 of "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1".
[ ERROR ]  Cannot infer shapes or values for node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1".
[ ERROR ]  Not all output shapes were inferred or fully defined for node "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1".
 For more information please refer to Model Optimizer FAQ (<INSTALL_DIR>/deployment_tools/documentation/docs/MO_FAQ.html), question #40.
[ ERROR ]
[ ERROR ]  It can happen due to bug in custom shape infer function <function Slice.infer at 0x7f20449d92f0>.
[ ERROR ]  Or because the node inputs have incorrect values/shapes.
[ ERROR ]  Or because input shapes are incorrect (embedded to the model or passed via --input_shape).
[ ERROR ]  Run Model Optimizer with --log_level=DEBUG for more information.
[ ERROR ]  Stopped shape/value propagation at "Postprocessor/BatchMultiClassNonMaxSuppression/map/while/Slice_1" node.
 For more information please refer to Model Optimizer FAQ (<INSTALL_DIR>/deployment_tools/documentation/docs/MO_FAQ.html), question #38.
Shubha_R_Intel
Dear Purohit, Rushikesh S,
Did you ever resolve this ? I would like to help you with this issue but I don't have access to Dropbox. If you wish to transfer huge files (such as models) to me you can do so via Syncplicity - that is the easiest way.
You say that the model is "pre-trained". I assume this to mean that the customer did not custom train it. Is this the case ? Is it one of these models listed model optimizer supported tensorflow list ?
Thanks and I'm sorry it took so long to address this,
Shubha
