Model Optimizer VGG19 error
Truong__Dien_Hoa
New Contributor II
I'm trying to convert the vgg_19 tensorflow slim model that I downloaded from here: https://github.com/tensorflow/models/tree/master/research/slim
Then I export the inference graph by running:
python3 models/research/slim/export_inference_graph.py --model_name vgg_19 --output_file ~/vgg_19.pb
However when I optimize it with openvino, the error below appears:
python3 /opt/intel/computer_vision_sdk/deployment_tools/model_optimizer/mo_tf.py --input_model ~/VGG19/vgg_19.pb --input_checkpoint ~/VGG19/vgg_19.ckpt -b 1 --mean_value [103.94,116.78,123.68] --scale 1
[ FRAMEWORK ERROR ]  Cannot load input model: Assign requires shapes of both tensors to match. lhs shape= [1,1,4096,1001] rhs shape= [1,1,4096,1000]
I think the problem come from the checkpoint file and the exported file doesn't have the same outputs shape, 1000 and 1001. I searched and found that this might be VGG Imagenet have a background class added to 1000 classes.
Can someone help me to fix this problem ?
Thank you
Truong__Dien_Hoa
New Contributor II
It seems like I can solve the problem when adding --labels_offset 1 in export_inference_graph.py
python3 models/research/slim/export_inference_graph.py --model_name vgg_19 --output_file ~/VGG19/vgg_19.pb --labels_offset 1
With that I can sucessfully create IR model
Haven't tested if the inference is ok.
