6595 Discussions
Model Optimizer Verification scripts error.
Mwangi__Keith
`The demo was unable to start correctly, what could be the problem with this?
Microsoft Windows [Version 10.0.18362.30]
(c) 2019 Microsoft Corporation. All rights reserved.
C:\Users\Keith Macharia>cd C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\
C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo>demo_squeezenet_download_convert_run.bat
target_precision = FP16
Python 3.6.7
ECHO is off.
PYTHONPATH=C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\accuracy_checker;C:\Program Files (x86)\IntelSWTools\openvino\python\python3.6;C:\Program Files (x86)\IntelSWTools\openvino\python\python3;
[setupvars.bat] OpenVINO environment initialized
INTEL_OPENVINO_DIR is set to C:\Program Files (x86)\IntelSWTools\openvino
Python 3.6.7
ECHO is off.
Requirement already satisfied: pyyaml in c:\users\keith macharia\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 1)) (5.2)
Requirement already satisfied: requests in c:\users\keith macharia\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.18.4)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\keith macharia\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (3.0.4)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\keith macharia\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (1.22)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\keith macharia\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2019.11.28)
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\keith macharia\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.6)
Download public squeezenet1.1 model
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name squeezenet1.1 --output_dir C:\Users\Keith Macharia\Documents\Intel\OpenVINO\openvino_models\models --cache_dir C:\Users\Keith Macharia\Documents\Intel\OpenVINO\openvino_models\cache
error: unrecognized arguments: Macharia\Documents\Intel\OpenVINO\openvino_models\models Macharia\Documents\Intel\OpenVINO\openvino_models\cache
usage: downloader.py [-h] [-c CONFIG.YML] [--name PAT[,PAT...]]
                     [--list FILE.LST] [--all] [--print_all]
                     [--precisions PREC[,PREC...]] [-o DIR] [--cache_dir DIR]
                     [--num_attempts N] [--progress_format {text,json}]
optional arguments:
  -h, --help            show this help message and exit
  -c CONFIG.YML, --config CONFIG.YML
                        model configuration file (deprecated)
  --name PAT[,PAT...]   download only models whose names match at least one of
                        the specified patterns
  --list FILE.LST       download only models whose names match at least one of
                        the patterns in the specified file
  --all                 download all available models
  --print_all           print all available models
                        download only models with the specified precisions
                        (actual for DLDT networks)
  -o DIR, --output_dir DIR
                        path where to save models
  --cache_dir DIR       directory to use as a cache for downloaded files
  --num_attempts N      attempt each download up to N times
                        which format to use for progress reporting
squeezenet1.1 model downloading completed
Waiting for 0 seconds, press a key to continue ...
Target folder C:\Users\Keith Macharia\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\Keith Macharia\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 folder.
###############|| Generate VS solution for Inference Engine samples using cmake ||###############
Creating Visual Studio 15 2017 x64 files in C:\Users\Keith Macharia\Documents\Intel\OpenVINO\inference_engine_samples_build...
-- Selecting Windows SDK version 10.0.17763.0 to target Windows 10.0.18362.
-- The C compiler identification is MSVC 19.16.27034.0
-- The CXX compiler identification is MSVC 19.16.27034.0
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x64/cl.exe
-- Check for working C compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x64/cl.exe -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x64/cl.exe
-- Check for working CXX compiler: C:/Program Files (x86)/Microsoft Visual Studio/2017/Community/VC/Tools/MSVC/14.16.27023/bin/Hostx86/x64/cl.exe -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Check size of __int32
-- Check size of __int32 - done
-- Found InferenceEngine: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/inference_engine.lib (Required is at least version "2.1")
-- Performing Test HAVE_CPUID_INFO
-- Performing Test HAVE_CPUID_INFO - Success
-- Host CPU features:
--   3DNOW not supported
--   3DNOWEXT not supported
--   ABM not supported
--   ADX not supported
--   AES supported
--   AVX supported
--   AVX2 supported
--   AVX512CD not supported
--   AVX512F not supported
--   AVX512ER not supported
--   AVX512PF not supported
--   BMI1 supported
--   BMI2 supported
--   CLFSH supported
--   CMPXCHG16B supported
--   CX8 supported
--   ERMS supported
--   F16C supported
--   FMA supported
--   FSGSBASE supported
--   FXSR supported
--   HLE not supported
--   INVPCID supported
--   LAHF supported
--   LZCNT supported
--   MMX supported
--   MMXEXT not supported
--   MONITOR supported
--   MOVBE supported
--   MSR supported
--   OSXSAVE supported
--   PCLMULQDQ supported
--   POPCNT supported
--   PREFETCHWT1 not supported
--   RDRAND supported
--   RDSEED not supported
--   RDTSCP supported
--   RTM not supported
--   SEP supported
--   SHA not supported
--   SSE supported
--   SSE2 supported
--   SSE3 supported
--   SSE4.1 supported
--   SSE4.2 supported
--   SSE4a not supported
--   SSSE3 supported
--   SYSCALL supported
--   TBM not supported
--   XOP not supported
--   XSAVE supported
-- TBB include: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/external/tbb/include
-- TBB Release lib: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Release/tbb.lib
-- TBB Debug lib: C:/Program Files (x86)/IntelSWTools/openvino/deployment_tools/inference_engine/lib/intel64/Debug/tbb_debug.lib
-- Looking for pthread.h
-- Looking for pthread.h - not found
-- Found Threads: TRUE
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Keith Macharia/Documents/Intel/OpenVINO/inference_engine_samples_build
###############|| Build Inference Engine samples using MS Visual Studio (MSBuild.exe) ||###############
C:\Program Files (x86)\Microsoft Visual Studio\2017\Community\MSBuild\15.0\Bin\MSBuild.exe" Samples.sln /p:Configuration=Release /t:classification_sample_async /clp:ErrorsOnly /m
Microsoft (R) Build Engine version 15.9.21+g9802d43bc3 for .NET Framework
Copyright (C) Microsoft Corporation. All rights reserved.
###############|| Run Inference Engine classification sample ||###############
The system cannot find the path specified.
        0 file(s) copied.
classification_sample_async.exe -i "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car.png" -m "C:\Users\Keith Macharia\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16\squeezenet1.1.xml" -d CPU
###############|| Classification demo completed successfully ||###############
Luis_at_Intel
Hi Mwangi, Keith,
As my peer Jesus mentioned, there seems to be an issue when there is a space in the models path. In your case "C:\Users\Keith Macharia\Documents\...", the space between the username is giving issues. I am able to reproduce and its seems to be a bug in the demo script.
Please edit the demo_squeezenet_download_convert_run.bat file under C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\ directory and make it look like this:
# line #102:
python "%downloader_dir%\downloader.py" --name "%model_name%" --output_dir "%models_path%" --cache_dir "%models_cache%"
# line #107:
if exist "%ir_dir%" (
You may need to modify the file as Administrator to be able to save the changes. Please give this a try an let me know the results, the changes worked for me.
Luis
JesusE_Intel
Hi Keith,
We have seen issues in the past with spaces in the user name. Would it be possible for you to try on another windows account or other system?
Jesus
Mwangi__Keith
How can I try it on another windows account?
Luis_at_Intel
Hi Mwangi, Keith,
# line #102:
# line #107:
Luis
Mwangi__Keith
It still did not work even after changing the user name
Microsoft Windows [Version 10.0.18362.657]
C:\Users\Keith>cd C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\
Python 3.6.7
ECHO is off.
Python 3.6.7
ECHO is off.
Requirement already satisfied: pyyaml in c:\users\keith\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 1)) (5.2)
Requirement already satisfied: requests in c:\users\keith\appdata\roaming\python\python36\site-packages (from -r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.18.4)
Requirement already satisfied: chardet<3.1.0,>=3.0.2 in c:\users\keith\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (3.0.4)
Requirement already satisfied: certifi>=2017.4.17 in c:\users\keith\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2019.11.28)
Requirement already satisfied: urllib3<1.23,>=1.21.1 in c:\users\keith\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (1.22)
Requirement already satisfied: idna<2.7,>=2.5 in c:\users\keith\appdata\roaming\python\python36\site-packages (from requests->-r C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\..\open_model_zoo\tools\downloader\requirements.in (line 2)) (2.6)
python "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\open_model_zoo\tools\downloader\downloader.py" --name squeezenet1.1 --output_dir C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\models --cache_dir C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\cache
################|| Downloading models ||################
========== Retrieving C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt from the cache
========== Retrieving C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.caffemodel from the cache
################|| Post-processing ||################
========== Replacing text in C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\models\public\squeezenet1.1\squeezenet1.1.prototxt
Target folder C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 already exists. Skipping IR generation with Model Optimizer.
If you want to convert a model again, remove the entire C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16 folder.
Creating Visual Studio 15 2017 x64 files in C:\Users\Keith\Documents\Intel\OpenVINO\inference_engine_samples_build...
--   AES supported
--   AVX supported
--   AVX2 supported
--   BMI1 supported
--   BMI2 supported
--   CLFSH supported
--   CX8 supported
--   ERMS supported
--   F16C supported
--   FMA supported
--   FXSR supported
--   LAHF supported
--   LZCNT supported
--   MMX supported
--   MOVBE supported
--   MSR supported
--   POPCNT supported
--   RDRAND supported
--   RDTSCP supported
--   SEP supported
--   SSE supported
--   SSE2 supported
--   SSE3 supported
--   SSE4.1 supported
--   SSE4.2 supported
--   SSSE3 supported
--   XSAVE supported
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Users/Keith/Documents/Intel/OpenVINO/inference_engine_samples_build
        1 file(s) copied.
classification_sample_async.exe -i "C:\Program Files (x86)\IntelSWTools\openvino\deployment_tools\demo\\car.png" -m "C:\Users\Keith\Documents\Intel\OpenVINO\openvino_models\ir\public\squeezenet1.1\FP16\squeezenet1.1.xml" -d CPU
