I was converting another yolo_v3 model with following arguments
/opt/intel/openvino/deployment_tools/model_optimizer$ python3 mo_tf.py --input_model ~/openvino_models/models/Customer/IONETWORK/frozen_darknet_yolov3_model.pb --tensorflow_use_custom_operations_config ./extensions/front/tf/yolo_v3.json --output_dir ~/openvino_models/models/Customer/IONETWORK/ --input_shape=[1,416,416,3] --data_type FP16
and get error like this
Model Optimizer version: 2019.1.1-83-g28dfbfd /opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/middle/passes/fusing/decomposition.py:65: RuntimeWarning: invalid value encountered in sqrt scale = 1. / np.sqrt(variance.value + eps) [ ERROR ] ------------------------------------------------- [ ERROR ] ----------------- INTERNAL ERROR ---------------- [ ERROR ] Unexpected exception happened. [ ERROR ] Please contact Model Optimizer developers and forward the following information: [ ERROR ] [ ERROR ] Traceback (most recent call last): File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/main.py", line 312, in main return driver(argv) File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/main.py", line 263, in driver is_binary=not argv.input_model_is_text) File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/pipeline/tf.py", line 141, in tf2nx graph_clean_up_tf(graph) File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/middle/passes/eliminate.py", line 186, in graph_clean_up_tf graph_clean_up(graph, ['TFCustomSubgraphCall', 'Shape']) File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/middle/passes/eliminate.py", line 181, in graph_clean_up add_constant_operations(graph) File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/middle/passes/eliminate.py", line 145, in add_constant_operations Const(graph, dict(value=node.value, shape=np.array(node.value.shape))).create_node_with_data(data_nodes=node) File "/opt/intel/openvino_2019.1.144/deployment_tools/model_optimizer/mo/ops/op.py", line 207, in create_node_with_data [np.array_equal(old_data_value[id], data_node.value) for id, data_node in enumerate(data_nodes)]) AssertionError [ ERROR ] ---------------- END OF BUG REPORT -------------- [ ERROR ] -------------------------------------------------
What caused this problem?
Thank you.
Dear SC Huang,
That is a strange error. Are you sure that you installed all the model optimizer pre-requisites ? What version of Tensorflow are you using ? My guess is that you did not perform Configure the Model Optimizer in your installation steps.
Shubha
Shubha R. (Intel) wrote:Dear SC Huang,
Shubha
Thanks Shubha,
But I'm sure I have installed those prequisites, I've successfully optimize most models downloaded from downloader.py before.
My tensorflow version is 1.12.0.
Retry after did MO config again, the Error is still the same.
![](/skins/images/D2683F18326913BBA0436CB7114DD569/responsive_peak/images/icon_anonymous_message.png)
