ModuleNotFoundError: No module named 'cv2'
STATEABC
When I run the demo in open_model_zoo, ModuleNotFoundError: No module named 'cv2' appears
Here are my operations:
source env.sh (including setupvars.sh, etc.)
jtagdir=$COREDLA_WORD/runtime/build_Release/fpga_jtag_reprogram
bitsdir=$COREDLA_WORD/demo/bitstreams
$jtagdir=/fpga_jtag_reprogram $bitsdir/AGX7_Performance.sof
curarch=$COREDLA_ROOT/example_architectures/AGX7_Performance.arch
Then run the script
But I installed opencv, and can run the demo without activating the environment
Any help would be greatly appreciated, thank you
Aznie_Intel
Hi Stateabc,
Thanks for reaching out. Which Open Model Zoo demo are you running? Usually, the error will arise when your Python environment cannot find the OpenCV package.
How did you install your OpenCV and what version are you using?
To install OpenCV, run pip install opencv-python
Aznie
STATEABC
I am running instance_setmentation_demo, my python environment can find opencv, when I run the following command in the terminal:
python3
>import cv2
>print(cv2.__version__)
it will print 4.10.0
If I don't activate the environment env and run the demo, the demo can run normally, which makes me very strange.
Thanks for your help
Aznie_Intel
Hi Stateabc,
Are you able to run the same command in OpenVINO environment? If you have multiple versions of python or OpenCV, try to uninstall it first. Then, install again the opencv-python version. The error might happen due to multiple versions of OpenCV in your system.
Aznie
Aznie_Intel
Hi Stateabc,
Thank you for your question. If you need any additional information from Intel, please submit a new question as this thread is no longer being monitored.
Aznie
