6577 Discussions
Movidius Installation problems I just can't get to install
Is there anyway to install 64-bit PC (AMD64) desktop ubuntu image? Tensorflow seems to want 64 bit version otherwise it fails. The other image is 32-bit PC (i386) desktop image and Tensorflow won't work. I have been at for two days now I really need some help. I would love to be able to use this product.
Reading installer configuration variables from ./ncsdk.conf
Your current combination of Linux distribution and distribution version is not officially supported! Error on line 42. Will exit
Makefile:47: recipe for target 'install' failed
make: *** [install] Error 1
Twice the wrong version of Ubuntu OS, first time 32 bit the second time version 18.x. Modified the installation install.sh to be 18.04 instead 16.04 and everything worked fine
if [ "${OS_DISTRO,,}" = "ubuntu" ] && [ ${OS_VERSION} = 1604 ]; then
[ "${VERBOSE}" = "yes" ] && echo "Installing on Ubuntu 16.04"
Modified too
if [ "${OS_DISTRO,,}" = "ubuntu" ] && [ ${OS_VERSION} = 1804 ]; then
[ "${VERBOSE}" = "yes" ] && echo "Installing on Ubuntu 18.04"
