Movidius NCS Installation Error
I am trying to install Movidius NCS from Movidius Start Guide .
But During installation step 2, I got an error as shown in the attachment.
`used as include directory in directory /opt/movidius/ssd-caffe/docs used as include directory in directory /opt/movidius/ssd-caffe/docs used as include directory in directory /opt/movidius/ssd-caffe/docs -- Configuring incomplete, errors occurred! See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeOutput.log". See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeError.log". make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[1]: *** No rule to make target 'all'. Stop. make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installing caffe... make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[1]: *** No rule to make target 'install'. Stop. make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installation failed. Error on line 535`
And I am not able to further continue the installations steps.
Please let me know how do I resolve it _
I'm getting a very similar error on Ubuntu 16.04 LTS
Compiling Caffe... -- Boost version: 1.58.0 -- Found the following Boost libraries: -- system -- thread -- filesystem -- regex -- chrono -- date_time -- atomic -- Could NOT find GFlags (missing: GFLAGS_INCLUDE_DIR GFLAGS_LIBRARY) -- Could NOT find Glog (missing: GLOG_INCLUDE_DIR GLOG_LIBRARY) CMake Error at /usr/share/cmake-3.5/Modules/FindPackageHandleStandardArgs.cmake:148 (message): Could NOT find Protobuf (missing: PROTOBUF_LIBRARY PROTOBUF_INCLUDE_DIR) Call Stack (most recent call first): /usr/share/cmake-3.5/Modules/FindPackageHandleStandardArgs.cmake:388 (_FPHSA_FAILURE_MESSAGE) /usr/share/cmake-3.5/Modules/FindProtobuf.cmake:308 (FIND_PACKAGE_HANDLE_STANDARD_ARGS) cmake/ProtoBuf.cmake:4 (find_package) cmake/Dependencies.cmake:24 (include) CMakeLists.txt:43 (include)
-- Configuring incomplete, errors occurred! See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeOutput.log". See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeError.log". make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[1]: *** No rule to make target 'all'. Stop. make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installing caffe... make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[1]: *** No rule to make target 'install'. Stop. make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installation failed. Error on line 498 ``
Only other thing in log I can see that might be issue is:
W: Invalid 'Date' entry in Release file /var/lib/apt/lists/_var_cuda-repo-8-0-local_Release W: Invalid 'Date' entry in Release file /var/lib/apt/lists/_var_libopencv4tegra-repo_Release
I'm assuming that's due to NVidia Jetpack being installed.
To get this far I had to resolve an issue with the mirrors not updating and install pip3 and cmake like this:
#Clean update: cd /etc/apt sudo mv sources.list sources.list.ok #Recreate sources.list and add these 4 lines to it. deb mirror://mirrors.ubuntu.com/mirrors.txt xenial main restricted universe multiverse deb mirror://mirrors.ubuntu.com/mirrors.txt xenial-updates main restricted universe multiverse deb mirror://mirrors.ubuntu.com/mirrors.txt xenial-backports main restricted universe multiverse deb mirror://mirrors.ubuntu.com/mirrors.txt xenial-security main restricted universe multiverse sudo apt-get clean sudo apt-get update sudo apt install python3-pip sudo apt-get install cmake
Hello, I have very similar error problem in Ubuntu 16.04 LTS, too.
There is an Error about NO_PUBKEY.
Installer NCSDK version: 1.12.00.01 Creating setup directory... Remove previous NCSDK references from PYTHONPATH...done Ign:1 http://dl.google.com/linux/chrome/deb stable InRelease Hit:2 http://dl.google.com/linux/chrome/deb stable Release Hit:4 http://storage.googleapis.com/bazel-apt stable InRelease Get:5 http://ppa.launchpad.net/fkrull/deadsnakes/ubuntu xenial InRelease [17.5 kB] Ign:5 http://ppa.launchpad.net/fkrull/deadsnakes/ubuntu xenial InRelease Hit:6 http://ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial InRelease Hit:7 http://ppa.launchpad.net/webupd8team/java/ubuntu xenial InRelease Hit:8 http://ppa.launchpad.net/webupd8team/y-ppa-manager/ubuntu xenial InRelease Fetched 17.5 kB in 3s (5091 B/s) Reading package lists... W: GPG error: http://ppa.launchpad.net/fkrull/deadsnakes/ubuntu xenial InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 5BB92C09DB82666C W: The repository 'http://ppa.launchpad.net/fkrull/deadsnakes/ubuntu xenial InRelease' is not signed.
Compiling Caffe... -- Boost version: 1.58.0 -- Found the following Boost libraries: -- system -- thread -- filesystem -- regex -- chrono -- date_time -- atomic -- Found gflags (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libgflags.so) -- Found glog (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libglog.so) -- Found PROTOBUF Compiler: /usr/bin/protoc -- Found lmdb (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/liblmdb.so) -- Found LevelDB (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libleveldb.so) -- Found Snappy (include: /usr/include, library: /usr/lib/x86_64-linux-gnu/libsnappy.so) -- -- CUDA is disabled. Building without it... -- OpenCV ARCH: -- OpenCV RUNTIME: -- OpenCV STATIC: OFF CMake Warning at /home/sirens/opencv-3.1.0/cmake/OpenCVConfig.cmake:166 (message): Found OpenCV Windows Pack but it has no binaries compatible with your configuration. You should manually point CMake variable OpenCV_DIR to your build of OpenCV library. Call Stack (most recent call first): cmake/Dependencies.cmake:74 (find_package) CMakeLists.txt:43 (include) CMake Error at cmake/Dependencies.cmake:74 (find_package): Found package configuration file: /home/username/opencv-3.1.0/cmake/OpenCVConfig.cmake but it set OpenCV_FOUND to FALSE so package "OpenCV" is considered to be NOT FOUND. Call Stack (most recent call first): CMakeLists.txt:43 (include)
I wonder where the problem is. Please let me know how do I resolve it. Thanks alot.
Hello, @sirens
Does not the following serve as a reference?
https://github.com/deadsnakes/issues/issues/53
I'm sorry if my prediction is missing…
Hello, @PINTO Thanks for your help. I followed the step and solved the NO_PUBKEY problem. But I still have the problem about openCV. If anyone knows, please let me know how to resolve it. Thanks alot. <pre><code> CMake Warning at /home/sirens/opencv-3.1.0/cmake/OpenCVConfig.cmake:166 (message): Found OpenCV Windows Pack but it has no binaries compatible with your configuration. You should manually point CMake variable OpenCV_DIR to your build of OpenCV library. Call Stack (most recent call first): cmake/Dependencies.cmake:74 (find_package) CMakeLists.txt:43 (include) CMake Error at cmake/Dependencies.cmake:74 (find_package): Found package configuration file: /home/username/opencv-3.1.0/cmake/OpenCVConfig.cmake but it set OpenCV_FOUND to FALSE so package "OpenCV" is considered to be NOT FOUND. Call Stack (most recent call first): CMakeLists.txt:43 (include) -- Configuring incomplete, errors occurred! See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeOutput.log". See also "/opt/movidius/ssd-caffe/build/CMakeFiles/CMakeError.log". make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[1]: *** No rule to make target 'all'. Stop. make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installing caffe... make[1]: Entering directory '/opt/movidius/ssd-caffe/build' make[1]: *** No rule to make target 'install'. Stop. make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installation failed. Error on line 498 </pre></code>
Hello, @sirens
https://github.com/opencv/opencv/issues/6132
Hello, @PINTO. Thanks for your replied.
I followed the serve as a reference, but it seems not working.
Actually, I do not know what the problem is ……
I uninstalled the opencv 3.1.0, and tried opencv 3.4.0. Then it occured another problem like this.
... ../lib/libcaffe.so.1.0.0-rc3: undefined reference to `leveldb::Status::ToString() const' ../lib/libcaffe.so.1.0.0-rc3: undefined reference to `google::protobuf::internal::WireFormatLite::WriteString(int, std::string const&, google::protobuf::io::CodedOutputStream*)' collect2: error: ld returned 1 exit status tools/CMakeFiles/compute_image_mean.dir/build.make:137: recipe for target 'tools/compute_image_mean' failed make[3]: *** [tools/compute_image_mean] Error 1 make[3]: Leaving directory '/opt/movidius/ssd-caffe/build' CMakeFiles/Makefile2:479: recipe for target 'tools/CMakeFiles/compute_image_mean.dir/all' failed make[2]: *** [tools/CMakeFiles/compute_image_mean.dir/all] Error 2 make[2]: Leaving directory '/opt/movidius/ssd-caffe/build' Makefile:127: recipe for target 'all' failed make[1]: *** [all] Error 2 make[1]: Leaving directory '/opt/movidius/ssd-caffe/build' Installation failed. Error on line 498
@sirens
Maybe this.
It seems that there is a compatibility between CUDA and GCC versions.
https://github.com/BVLC/caffe/issues/5128
Sorry, I can not try it because it does not reproduce in my environment.
Hi, I am having the same problem as mentioned above. Did someone find a solution?
Hi, just experimenting the same issue on my second machine on ubuntu 16.04
nvcc --version = 9.1.85 gcc --version = 5.4.0
To me, the issue comes from the Caffe installation.
Looking at your stack trace it seems that in your caffe has an issue with open-cv
This said, as natively caffe installs open-cv, maybe try to remove it and let it be installed by the process.
Hi everyone, i need a help who can a tell me how i can resolve the same issue :
Installing caffe…
