Retraining with fewer classes
Hi
So I took the COCO SSD 300 model from here:
https://github.com/weiliu89/caffe/tree/ssd
File here:
https://drive.google.com/open?id=0BzKzrI_SkD1_dUY1Ml9GRTFpUWc
I changed the output from:
layer {
type: "DetectionOutput"
bottom: "mbox_loc"
bottom: "mbox_conf_flatten"
bottom: "mbox_priorbox"
top: "detection_out"
include {
phase: TEST
detection_output_param {
num_classes: 81
share_location: true
background_label_id: 0
nms_param {
nms_threshold: 0.45
top_k: 400
save_output_param {
label_map_file: "data/coco/labelmap_coco.prototxt"
code_type: CENTER_SIZE
keep_top_k: 200
confidence_threshold: 0.01
To this:
layer {
bottom: "mbox_loc"
include {
phase: TEST
num_classes: 81
nms_param {
nms_threshold: 0.45
top_k: 100
keep_top_k: 100
confidence_threshold: 0.3
The accuracy seems low but the main issue is it runs at about 1.5 seconds per frame. Any ideas why?
Is it because there are the full 91 classes?
To get the good performance of the 20 class SSD Demo file will I need to retrain with 20 classes only?
Cheers,
Dan
