6574 Discussions
Movidius not found when attempting to load a graph
robert_osmosis
Hello, I am trying to run the following code:
from inference_engine import IENetwork, IEPlugin
def debug_movidius():
    plugin = IEPlugin(device='MYRIAD')
    net = IENetwork(model='cars.xml', weights='cars.bin')
    input_blob = next(iter(net.inputs))
    out_blob = next(iter(net.outputs))
    exec_net = plugin.load(network=net, num_requests=2, config={"VPU_LOG_LEVEL": "LOG_DEBUG"})
    print(input_blob)
    print(out_blob)
    print(exec_net)
if __name__ == '__main__':
    debug_movidius()
I am running the script from the inside of a docker container which does have access to the NCStick, I am running it in privileged mode and have tested with lsusb that it does have access to them.
However this is the error I am getting:
[setupvars.sh] OpenVINO environment initialized
Using TensorFlow backend.
D: [ncAPI] [    220158] ncDeviceCreate:328      ncDeviceCreate index 0
D: [ncAPI] [    220158] resetAll:246    Found stalled device 2.5-
D: [xLink] [    220158] XLinkConnect:971        XLinkConnect() device name 2.5-
D: [xLink] [    220158] dispatcherStart:836     dispatcherStart() starting a new thread - schedulerId 0
D: [xLink] [    220158] dispatcherAddEvent:661  receiving event USB_PING_REQ 0
D: [xLink] [    220158] addNextQueueElemToProc:411      D: [xLink] [    220158] eventSchedulerRun:538   eventSchedulerRun() schedulerId 0
received event USB_PING_REQ 0
I: [xLink] [    220158] eventSchedulerRun:569   Scheduler thread started
D: [xLink] [    220158] dispatcherLocalEventGetResponse:607     USB_PING_REQ
I: [xLink] [    220158] eventReader:239 eventReader started
D: [xLink] [    220158] dispatcherRequestServe:315      ------------------------UNserved USB_PING_REQ
D: [xLink] [    220158] dispatcherEventSend:885 USB_PING_REQ, size 0, streamId 0.
D: [xLink] [    220159] dispatcherEventReceive:301      Incoming event 0x7fe7abf8bee0: USB_RESET_RESP 11 0x46add70 prevEvent: USB_WRITE_REQ 0 (nil)
D: [xLink] [    220159] handleIncomingEvent:219 USB_RESET_RESP, size -1515870811, streamId -1515870811.
D: [xLink] [    220159] dispatcherAddEvent:661  receiving event USB_RESET_RESP 1
D: [xLink] [    220159] addNextQueueElemToProc:411      received event USB_RESET_RESP 1
D: [xLink] [    220159] eventReader:244 Reading USB_RESET_RESP (scheduler 0, fd 0x46add70, event id 11, event stream_id -1515870811, event size -1515870811)
I: [xLink] [    220159] eventReader:248 eventReader stopped
E: [xLink] [    220269] dispatcherEventSend:889 Write failed header -4 | event USB_PING_REQ
I: [xLink] [    220269] dispatcherReset:502     Resetting...
I: [xLink] [    220269] dispatcherReset:514     dropped event is USB_RESET_RESP, status 0
I: [xLink] [    220269] dispatcherReset:523     Pending event is USB_PING_REQ, size is 0, Mark it served
I: [xLink] [    220269] closeDeviceFdAndResetScheduler:474      Dispatcher Cleaning...
I: [xLink] [    220269] closeDeviceFdAndResetScheduler:487      Cleaning Successfully
I: [xLink] [    220269] eventSchedulerRun:623   Scheduler thread stopped
I: [ncAPI] [    220269] resetAll:268    Stalled devices found, Reseting...
D: [xLink] [    220269] getXLinkState:918       getXLinkState() link 0x7fe7ad1494a0 link->peerState 1
D: [xLink] [    220269] XLinkResetRemote:1404   sending reset remote event
W: [xLink] [    220269] XLinkResetAll:1431      Failed to reset
I: [ncAPI] [    220519] resetAll:293    ...
I: [ncAPI] [    220770] resetAll:293    ...
I: [ncAPI] [    221020] resetAll:293    ...
I: [ncAPI] [    221270] resetAll:293    ...
I: [ncAPI] [    221520] resetAll:293    ...
I: [ncAPI] [    221771] resetAll:293    ...
I: [ncAPI] [    222021] resetAll:293    ...
I: [ncAPI] [    222271] resetAll:293    ...
I: [ncAPI] [    222521] resetAll:293    ...
I: [ncAPI] [    222771] resetAll:293    ...
I: [ncAPI] [    223022] resetAll:293    ...
I: [ncAPI] [    223272] resetAll:293    ...
I: [ncAPI] [    223522] resetAll:293    ...
I: [ncAPI] [    223773] resetAll:293    ...
I: [ncAPI] [    224023] resetAll:293    ...
I: [ncAPI] [    224273] resetAll:293    ...
I: [ncAPI] [    224523] resetAll:293    ...
I: [ncAPI] [    224773] resetAll:293    ...
I: [ncAPI] [    225024] resetAll:293    ...
I: [ncAPI] [    225274] resetAll:293    ...
I: [ncAPI] [    225524] ncDeviceSetOption:2358  Set watchdog interval to: 1000
I: [ncAPI] [    225524] ncDeviceDestroy:1226    Destroying Device
D: [ncAPI] [    225524] ncDeviceCreate:328      ncDeviceCreate index 1
W: [ncAPI] [    227524] ncDeviceCreate:395      Failed to init device, rc: X_LINK_DEVICE_NOT_FOUND
Traceback (most recent call last):
  File "edge/main.py", line 53, in <module>
    debug_movidius()
  File "edge/main.py", line 21, in debug_movidius
  File "ie_api.pyx", line 389, in openvino.inference_engine.ie_api.IEPlugin.load
  File "ie_api.pyx", line 400, in openvino.inference_engine.ie_api.IEPlugin.load
RuntimeError: Can not init USB device: NC_DEVICE_NOT_FOUND
robert_osmosis
SOLVED:
I was installing python3.6 after installing the openvino libraries and for some weird reason it was causing openvino/python to stop recognizing the movidius sticks.
What I did to solve it was to install the openvino libraries AFTER installing python3.6
Shubha_R_Intel
Dear Rios, Robert,
It's weird that order of installation matters but I'm glad you fixed it. Thanks for reporting back and sharing your knowledge with the OpenVino community !
Shubha
