Multi Stage detectors data map
shekarneo
I have the dlstreamer pipeline below, and I am using person detection and face detection models. I am attempting to associate person bounding boxes with their corresponding faces. However, dlstreamer provides separate lists for persons and faces, making it challenging to determine which face belongs to each person.
Could you please assist me in figuring out how to match the faces with their respective persons?
Below, you can find the pipeline and the complete code.
filesrc location=t1.jpg ! decodebin \
                                ! videoscale ! video/x-raw,width=640,height=640 \
                                ! videoconvert ! capsfilter caps=video/x-raw,format=BGR \
                                ! queue ! gvadetect model=../person_head_detection/models/yolov5_80cls/yolov5s_openvino_model/FP32/yolov5s.xml model-proc=../person_head_detection/models/model_proc/yolo-v5_80.json device=CPU threshold=0.8 name=gvadetect_yolov5 \
                                ! queue ! gvatrack tracking-type=short-term-imageless \
                                ! queue ! gvadetect model=models/face-detection-0204/FP32/face-detection-0204.xml model-proc=models/model_proc/face-detection-0204.json device=CPU threshold=0.8 inference-region=roi-list name=gvadetect_face \
                                ! queue ! gvawatermark name=gvawatermark \
                                ! queue ! videoconvert n-threads=4 ! fpsdisplaysink sync=false
from collections import defaultdict
from pathlib import Path
import time
import sys
import gi
from datetime import datetime
import logging
import cv2
import numpy as np
import copy
import os
gi.require_version("Gst", "1.0")
gi.require_version("GstApp", "1.0")
gi.require_version("GstVideo", "1.0")
gi.require_version("GObject", "2.0")
from gi.repository import Gst, GLib, GstApp, GstVideo
from gstgva import VideoFrame, util
import uuid
from datetime import timedelta
Gst.init(sys.argv)
def bus_call(bus, message, loop):
    t = message.type
    if t == Gst.MessageType.EOS:
        sys.stdout.write("End-of-stream\n")
        loop.quit()
    elif t==Gst.MessageType.WARNING:
        err, debug = message.parse_warning()
        sys.stderr.write("Warning: %s: %s\n" % (err, debug))
    elif t == Gst.MessageType.ERROR:
        err, debug = message.parse_error()
        sys.stderr.write("Error: %s: %s\n" % (err, debug))
        loop.quit()
    return True
class Pipeline:
    def __init__(self):
        self.pipeline_string = f"filesrc location=t1.jpg ! decodebin \
                                ! queue ! videoconvert n-threads=4 ! fpsdisplaysink sync=false"
        self.detected_frames = {}
        self.frame_number=0
        self.save_dir = "crop_data"
        #                                ! queue ! gvametaconvert ! gvametapublish file-format=json-lines file-path=output.json \
    def frame_callback(self, frame):
        detected_ids = []
        self.frame_number += 1
        ts = frame._VideoFrame__buffer.pts
        with frame.data() as img:
            for roi in frame.regions():
                # print(roi.meta().parent_id)
                # print(dir(roi))
                # print(dir(roi.meta()))
                print(f"roi: {roi.label()}-{roi.object_id()}")
                if roi.label() == "person":
                    bbox = roi.rect()
                    obj_id = roi.object_id()
                    p_conf = roi.confidence()
                if roi.label() == "face":
                    # print(roi.label())
                    # print(roi.confidence())
                    # print(bbox)
                    # print(roi.rect())
                    f_conf = roi.confidence()
                    x,y,w,h = bbox
                    x1 = int(x)
                    x2 = int(x) + int(w)
                    y2 = int(y) + int(h)
                    y1 = int(y)
                    if h > 2*w:
                        crop = img[y:y+h, x:x+w]
                        if not os.path.exists(f"{self.save_dir}/{obj_id}"):
                            os.makedirs(f"{self.save_dir}/{obj_id}")
                        cv2.imwrite(f"{self.save_dir}/{obj_id}/person_{self.frame_number}_{p_conf}_{f_conf}.jpg", crop)
                # if roi.label_id() == 0:
                #     for tensor in roi.tensors():
                #         if 'reid_embedding' in tensor.name():
                #             person_descriptor = tensor.data().tolist()
                #             print(len(person_descriptor))
                #             cv2.imwrite("test.jpg", img)
                # roi.add_tensor("confidence").set_label(f"{roi.confidence():.2f}")
        return True
    def detect_pad_probe_callback(self, pad, info):
        with util.GST_PAD_PROBE_INFO_BUFFER(info) as buffer:
            caps = pad.get_current_caps()
            frame = VideoFrame(buffer, caps=caps)
            image_width = frame.video_info().width
            image_height = frame.video_info().height
            self.frame_callback(frame)
        return Gst.PadProbeReturn.OK
    def watermark_pad_probe_callback(self, pad, info):
    # def on_message(self, bus: Gst.Bus, message: Gst.Message, loop: GLib.MainLoop):
    #     mtype = message.type
    #     if mtype == Gst.MessageType.EOS:
    #         self.cv_plot()
    #         self.pipeline.set_state(Gst.State.NULL)
    def run(self):
        pipeline = Gst.parse_launch(self.pipeline_string)
        loop = GLib.MainLoop()
        bus = pipeline.get_bus()
        bus.add_signal_watch()
        bus.connect("message", bus_call, loop)
        # detect_pad = pipeline.get_by_name("gvainference")
        # if detect_pad:
        #     pad = detect_pad.get_static_pad("src")
        #     pad.add_probe(Gst.PadProbeType.BUFFER, self.detect_pad_probe_callback)
        gvawatermark = pipeline.get_by_name("gvawatermark")
        if gvawatermark:
            pad = gvawatermark.get_static_pad("src")
            pad.add_probe(Gst.PadProbeType.BUFFER, self.watermark_pad_probe_callback)
        # graypad = pipeline.get_by_name("gray")
        # if graypad:
        #     pad = graypad.get_static_pad("src")
        #     pad.add_probe(Gst.PadProbeType.BUFFER, self.pad_probe_callback)
        pipeline.set_state(Gst.State.PLAYING)
        try:
            loop.run()
        except Exception as e:
            logging.error("Exception")
            loop.quit()
obj = Pipeline()
obj.run()
Aznie_Intel
Hi Shekarneo,
Thanks for reaching out.
You may refer face_detection_and_classification.sh for the pipeline elements used in Face Detection And Classification Sample. The sample output visualizes video with bounding boxes around detected faces, facial landmarks points and text with classification results (age/gender, emotion) for each detected face or prints out fps if you set SINK_ELEMENT = fps
Hope this helps.
Aznie
shekarneo
Hi Aznie,
This will work when we have primary as detector and secondary as classifier.
but the same is not working with both primary and secondary as detectors
like gvadetect(person detector)->gvatracker->gvadetect(face detector)
Aznie_Intel
Hi Shekarneo,
It is expected since Face Detection And Classification Sample builds GStreamer pipeline of the following elements
  • gvadetect for face detection based on OpenVINO™ Toolkit Inference Engine
  • gvaclassify inserted into pipeline three times for face classification on three DL models (age-gender, emotion, landmark points)
  • gvawatermark for bounding boxes and labels visualization
The gvatrack element is used in Vehicle and Pedestrian Tracking Sample for object tracking capabilities.
Aznie
Aznie_Intel
Hi Shekarneo,
This thread will no longer be monitored since we have provided information. If you need any additional information from Intel, please submit a new question.
Aznie
PrincePatel
@Aznie_Intel Facing the same issue here : https://github.com/dlstreamer/dlstreamer/issues/430
The dlstreamer has resolved this in 2022.1 release pointed here: https://github.com/dlstreamer/dlstreamer/issues/206#issuecomment-1188346806
But it is an issue now. Can we resolve this?
