OpenVINO and SYCL compatibility issues
yaoy
I am working on a project that requires the use of both SYCL for computations running on GPU and OpenVINO for model inference on NPU. However, I'm encountering a compatibility issue between the two.
Please refer to the following example code that reproduces the issue. If OpenVINO runtime is initialized first, an exception is triggered when creating a SYCL queue. Conversely, if the queue is created first, OpenVINO fails to detect the NPU device.
Please let me know if it is expected that OpenVINO is incompatible with SYCL, or if there is anything I need to do for them to work together. Thanks a lot!
My device, driver, and platform specifications are as follows.
Processor:       Intel(R) Core(TM) Ultra 9 185H   3.40 GHz
System type:  64-bit operating system, x64-based processor
Windows specifications:
    Edition:            Windows 11 Enterprise
    Version:           21H2
    OS build:         22000.3079
    Experience:     Windows Feature Experience Pack 1000.22004.1000.0
Visual Studio Enterprise 2022 (64-bit):
    Version: 17.10.5
    Compiler: Intel(R) oneAPI DPC++ Compiler 2024.2.0 (2024.2.0.20240602)
OpenVINO Runtime:
    Version : 2024.2.0
    Build   : 2024.2.0-15519-5c0f38f83f6-releases/2024/2
SYCL Platform Information:
    Name: Intel(R) Level-Zero
    Vendor: Intel(R) Corporation
    Version: 1.3
GPU Device Information:
    Name: Intel(R) Arc(TM) Graphics
    Driver Version: 32.0.101.5768
NPU Device Information:
    Name: Intel(R) AI Boost
    Driver version: 31.0.100.1688
Iffa_Intel
Have you tried to put on some delay to ensure one process is finished before executing another?.
The most efficient way to do this is actually by implementing multithreading.
Cordially,
Iffa
yaoy
Hi Iffa,
Yes, I have tried using multithreading where one thread creates SYCL queue and another thread uses OpenVINO, in order to isolate their impacts to each other. I have made sure that one is finished before executing another, but unfortunately this does not resolve the issue. I still see them impacting each other the same way as when no multithreading is used.
Best,
Yao
Iffa_Intel
If the issue persists even before implementing SYCL, perhaps it's related to the OpenVINO installation itself.
Could you clarify:
  1. Did you manage to run OpenVINO on your system without any issues before implementing any other additional functions? (perhaps try to run one of the OpenVINO Sample Application)
  2. Have you consider of using OpenVINO Threading Utilities ?.
Cordially,
Iffa
Iffa_Intel
Thank you for your question. If you need any additional information from Intel, please submit a new question as Intel is no longer monitoring this thread.
Cordially,
Iffa
