6616 Discussions
Change the timecode setting for OpenVino Whisper transcription?
Rosetree
Hello.
I am wondering....
Is there a way to change the time code setting of the Whisper Transcription script when used in Audacity so that it puts out h:m:s instead of just m:s?
I hope I am making sense.
It would be great if anybody could point me in the right direction.
Thank you in advance for your help!
Wan_Intel
Hi Rosetree,
For your information, we regret to inform you that changing the time code setting in OpenVINO™ Whisper Transcription is not available. The description of the properties that can be set can be found here. On another note, the implementation of Whisper Transcription and Translation can be found at Port of OpenAI's Whisper model in C/C++. Hope it helps.
Wan
Wan_Intel
Hi Rosetree,
Thanks for your question.
This case will no longer be monitored since we have provided an explanation. Please submit a new thread if you have any questions.
Wan
