Hello.
I am wondering....
Is there a way to change the time code setting of the Whisper Transcription script when used in Audacity so that it puts out h:m:s instead of just m:s?
I hope I am making sense.
It would be great if anybody could point me in the right direction.
Thank you in advance for your help!
链接已复制
2 回复数
Hi Rosetree,
For your information, we regret to inform you that changing the time code setting in OpenVINO™ Whisper Transcription is not available. The description of the properties that can be set can be found here. On another note, the implementation of Whisper Transcription and Translation can be found at Port of OpenAI's Whisper model in C/C++. Hope it helps.
Wan
